20 Most Recent Fuji Finepix S1500 10.0 Megapixel 12x Optical Zoom, 2.7 Inch LCD Screen Digital Camera Questions & Answers
Why won't my fugi finepix s4500 won't focus sharply ?
No good working auto focus can have many causes. Like the camera is in Macro mode, or manual focus. The best thing to try, is to switch your camera to the auto mode. The camera logo on your mode dial. And then shoot some pictures. There should be enough light and contrast in the frame, on the place you want the camera to focus on. Sometimes you have to chose an object, with enough details and contrast, on the same distance as the object you want to take a picture of. Then press the shutter half way, till the camera is in focus. the indicator lamp next to the mode dial glows green. Then frame the picture like you want it taken end only than press the shutter completely. If the camera does focus correct in the auto mode, then you can check, why it did not focus before. Check page 19 of the manual, to see how to use the shutter release button, for correct focus.
4/23/2014 9:07:33 PM • Fuji Finepix... • Answered on Apr 23, 2014
PROTECTED CARD CANNOT DELETE PICTURE
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
12/3/2013 9:45:50 PM • Fuji Finepix... • Answered on Dec 03, 2013
Needs a factory reset
The only reset I can find is on page 89 of the manual.link to FujiFilm Finepix S1500 manual
11/27/2013 8:41:43 AM • Fuji Finepix... • Answered on Nov 27, 2013
I have a fuji finepix s1500. I see the date/time stamp in the view finder but when I upload the image the stamp isn't there. How do I get it to upload on the images?
Hello Betty, Sounds like you need to go in to the menu and turn this on. May be listed under SETUP on the menu list.Best Regards, Russell
1/24/2013 1:29:16 AM • Fuji Finepix... • Answered on Jan 24, 2013
Focus error finepix hs10
About the HS10 autofocus problem, I discovered the cause and solution. It is a problem of camera design, and is caused by three screws securing the CCD sensor. These screws are not properly secured and the vibration eventually dropping. In two cameras with the same defect, the screws were loose. These screws adjust the sensor position relative to the lens and the sensor is loose when out of position not allowing proper focus. The solution is to disassemble the camera and secure the screws. These screws can not be too tight they need to be adjusted to position the CCD sensor correctly. The camera is difficult to dismantle because several wires are soldered. Care must be taken to discharge the capacitor of the flash, this may cause an electric shock and burn the camera board. Those who want to try the repair, follow the link to the service manual. http://elektrotanya.com/fujifilm_finepix_hs10_hs11_sm.pdf/download.html Milton Maenishi
1/5/2019 11:29:03 AM • Fuji FinePix... • Answered on Jan 05, 2019
I have a FinePix S1 and the display screen is not working. All other modes are working but no display
Many occasions LCD on camera display never fails but back light fails unless physical damage to LCD screen. Hold a torch to display when camera is on you will see faint(black and white) image means LCD is ok but back light is failed, it's replaceable but needs little skill to replace. Or replace full Screen with backlight. This is easy. Just remove back cover, remove display by loosening flex lock, put back new display carefully lock it holding flex with one finger. Please do not touch display flex contacts.
12/21/2018 2:22:04 PM • Fuji FinePix... • Answered on Dec 21, 2018
Finepix jz shutter not opening and zoom doesn't work
Time for a new camera, these are not repaired just exchanged, so the price is high, just replace it.
1/23/2017 8:54:23 PM • Fuji FinePix... • Answered on Jan 23, 2017
I am looking for lens-cap and case for my Fine Pix S1. Can you help?
Local friendly camera shop / manufacturer / Ebay
10/1/2016 8:24:47 PM • Fuji FinePix... • Answered on Oct 01, 2016
I am looking for a installation cd for my fuji finepix s1000fd camera - can l download one from the internet?
That should be possible - just Google the make and model, followed by the word software.
9/27/2016 2:11:08 PM • Fuji FinePix... • Answered on Sep 27, 2016
2answers
What do I need to connect my FinePix S700 to my computer
Why not remove the memory card and use a card reader attached to your computer ?
8/19/2016 12:48:28 PM • Fuji FinePix... • Answered on Aug 19, 2016
Fuji Finepix S1500 10.0 Megapixel 12x Optical Zoom, 2.7 Inch LCD Screen Digital Camera Logo
Popular Tags
10 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
needs factory reset
  • Cameras
