SOURCE: I'm using a CanoScan LiDE 60...
Use the CanoScan Toolbox that shipped with the scanner. If you don't have it, then download it from the Canon Website. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=11446
If you don't have the scanner driver, then download that too.
Once you have Toolbox installed and you open it, there will be a PDF button. The scan to PDF window will open. If you're planning to do a multiple page pdf, then click the dropdown menu next to 'Save as Type:' and select PDF (Multiple Pages). You're now ready to begin, insert your first page into and then click 'Scan'.
SOURCE: LiDE 600DF - Unable to scan
I think I might have solved my own problem, at least for the time being. If my theory is correct, then it might be a permanent solution.
I had been goint through the "CanoScan Toolbox 5" configuration line by line to see if anything would suggest a solution when I noticed that the "Folder for where temporary files are stored" had an enormously long path of C:\Documents and Settings\username\Application Data\Canon\TB50\...... By the time the temporary filename is added to the end, it may have exceeded the permissible length the system can handle. So I changed it to C:\Temp and it all started to work for me.
Worth a try for my fellow sufferers.
Trying4
SOURCE: I have a Cano Scan LiDE 200 scanner. Is there a
yes there is its called cute pdf
http://www.cutepdf.com/Products/CutePDF/writer.asp
and here is the link to download it just click on the link to the left free download and install it works really good
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SOURCE: my canon lide 100 scanner will e mail scanned
The scan to e-mail uses your default mail product. As of June 2008, Outlook Express can not check a Hotmail account. If you have XP, Vista or Win7, you can download and install Windows Live Mail and use that instead. Since Hotmail is a Microsoft product, Live Mail should set up the account without a problem (both the incoming server and the out-going server); all you'll need to add is your full email address ([email protected]) and password. Make your Hotmail account the default and Live Mail the default e-mail program and you should be good to go for sending e-mail via Hotmail.
If you want to continue with Outlook Express, there is no solution.
I hope this helps.
(Live Mail will ask if you want it to be the default program when you first launch it after installing (in my experience all mail programs do this). If you relaunch Outlook Express, it will ask the same question and you will need to reset the default program for mail. This can be done either as each program asks or through the Control Panel, Programs, Default Programs)
