CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
http://www.canon.com/printer/prob676ijt65/solution
pow-e-r-28
42 error definitely caused by loose flat cable from the scanner down into the electronics. End of the cable does not have a plug, just solder on each element, push the cable into its socket.
SOURCE: mp160 e42 error
hi,
CANON PIXMA MP160 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
mbhd2
SOURCE: Canon printer MP160, I keep getting an error
E42 Scanner error
Sorry thats all I can tell you maybe some eles will gave you more
All Best
SOURCE: canon mp160 error E42
Hello there ok
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Canon MP160 Error E42
Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
