XP3 with lj4+ driver installed. test page for xp prints weird font and letters are printed over each other. All text prints no problem from pdf or txt or doc files, except for bullets and hyperlinks or underlines.
lpt1 port is ecp+epp. tried spp same thing happens.
tried the laserjet III driver and same issue. Please help. It is a stock lj4+, 2m ram and no extras.
Try the lj4 not plus or the lj5 these have always worked fine for me if problem still persisits do a printer test print from the menu button on the printer to make sure that the issue is not a printer formatter board
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Hi devi960:
Pages print, but all
colors do not print or
the pages are
completely blank.
One of the print cartridges might be
low or empty.
Run an engine test and see if all four colors print. If
not all colors print, replace one or more of the print cartridges. If the
engine test is successful, replace the formatter.
If the printed pages are completely
blank, the file might have blank
pages.
Check the file to make sure that it does not contain blank pages.
A print cartridge might be low or
empty.
Check the printer control panel for a Supplies Status message,
print a Supplies Status page, or use the embedded Web server
(HP color LaserJet 2500 series printers only) to see the levels
remaining in the print cartridges. Replace any print cartridges that
are low or empty. Messages are not created for non-HP print
cartridges.
If you are using non-HP print
cartridges, one or more print
cartridges are low or empty. The
control panel lights do not indicate
low or empty for non-HP print
cartridges.
Replace one or more of the print cartridges.
Font DIMM might be selected but the
font DIMM is not physically installed in
the printer. (This issue applies only to
printers using an Asian-language font
DIMM.)
In the settings for this printer, clear the Font DIMM check box on
the Configure tab if no font DIMM is installed in the printer. Select
the Font DIMM check box only if the font DIMM is physically
installed in the printer. If you think that the font DIMM is installed,
make sure that it is installed correctly.
The paper curls when
exiting the top output
bin.
The paper needs to print to the
straight-through paper path.
Open the rear output door to print to the straight-through paper
path. Remove each sheet as it exits the printer.
The stack was slightly curled when it
was placed in the tray.
Turn the stack over in the tray.
The paper does not meet
specifications.
See the user guide for information about print-media specifications.
If you are printing on light media, the
Type setting might not be correct.
Select Light in the Type is field in the printer driver.
i would say reinstall the driver, wouldnt be a schoolboys trick even sometimes the schoolboys know more than the teachers when it comes to technology.
Try the machines with a seporate machine thats a freash install and see it does the same thing, this a driver issue, and sometimes the students can hack into the machine and asking the printer to just print just one page of the document, you can select pages in a print box in word / Internet explorer for example.
And you can ask the printer to print two pages onto one page.
wherer are you printing this, A4 is european, north america would use letter, etc..
if you go to control panel, open the printers and faxes folder, right click the printer in question, a window will pop up, click on properties.. a new window should open. click on "Printing Defaults" or "Printing Preferences" then click on "Advanced" ( I believe it should be to the lower left) that will open another window, in paper size make it Letter if your in N America, A4 for Euro.. this will set the deafult print..
Click ok, then print a test page from the general tab..
The reason you getting this LOAD LETTER message. your excel page setup is set to print to letter, your machine is set to print top A4
If you open Excel then go to Print then a window should pop up where you select the printer you want to use, click on Properties, then Lay out, then Advanced, and input the correct paper size before you print.
does this happen with all excels files, or one particular?
Create a new Excel file, and try printing it.. possibly could be in that particular file. I have seen this happen alott particulary with PDF files.. Where the incorrect paper size is in the file..
Clear the Print Que in the PC, turn off and unplug the machine, turn it back on.. send a test print from the driver.
A4 is european paper size, your printer is set for letter, someone attmepted to print an A4 file. Which is in the page set up in what ever file was to be printed.
Next Time Please be specific?
The
printer received more data form the computer than can fit
in its available user memory. You may have tried to
transfer too many macros or soft fonts, or graphics that
were too complex. This problem is also caused by printing
too many typefaces at 600dpi. Press
Continue to print the transferred data, then simplify
your print job or install additional memory. I don't know why it would just start doing it, perhaps a memory module has gone bad and there is not as much available RAM as there used to be?
this is a driver problem, try reinstalling the printer with the laserjet4 driver which is a universal PCL driver, this should solve the problem. If not, there is also a blank HP Laserjet driver
