Good Afternoon My tv switched it's self off and when I put it back on there's a white information line across the top which keeps running through all the scart connection devices available and all the free-view channels available. I can't set it to any device i.e, HMDI or manage to set it to any channel. I have had it switched off and unplugged for a week and have just connected it up again, but the problem is still there. Thank you Heid
SOURCE: white horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
SOURCE: Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
SOURCE: Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
SOURCE: cant connect playstation 2 to LG lcd tv
I have a sony bravia lcd digital color tv. I want to know how to plug in my play station 2? The PS2 has a coaxial cable running from it with a side coaxial connection. Where an how do i connect?
