20 Most Recent Mitsubishi WD-65735 Television Questions & Answers
Hi
Have you tuned the channel frequency tuner? Use the remote to bring up setup menu on TV, scan channel frequencies & save. If it's an old TV that can't pick up digital signals, then you need to get a digital set top box & tune to TV.
Mitsubishi... | Answered on Feb 07, 2018
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mitsubishi... | Answered on Sep 03, 2017
Replace the medieval TV.
Mitsubishi... | Answered on May 18, 2017
Likely a power supply problem.
There are some capacitors that are known to fail. Not user repairable usually. however if you want to, here is the service manual you can get for free.https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&uact=8&ved=0ahUKEwjasreLnqHPAhWK6yYKHYmrBSQQFgg-MAU&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F4%2F4617648b-f64b-45b6-a682-e6e867643cde.pdf&usg=AFQjCNG2jY9OC22f2LpfC5JEw5_BvLPjaQ&sig2=EOheTxtLJXzrkQgqQMd40A https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&uact=8&ved=0ahUKEwjasreLnqHPAhWK6yYKHYmrBSQQFgg-MAU&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F4%2F4617648b-f64b-45b6-a682-e6e867643cde.pdf&usg=AFQjCNG2jY9OC22f2LpfC5JEw5_BvLPjaQ&sig2=EOheTxtLJXzrkQgqQMd40A
Mitsubishi... | Answered on Sep 21, 2016
maybe there's nothing wrong with the chip you can try to restart the system
Mitsubishi... | Answered on May 14, 2016
it is your dlp chip i just changed mine make sure it is in tight ther is a video on you tube that is very helpful mine did the same thing with the lines untill i got the dlp chip in tight
Mitsubishi... | Answered on Nov 03, 2015
open mitsubishi front door see volumn control push button use +/- if you need new remote part no: Manufacturer Mitsubishi Part Number 290P123010 Description REMOTE
Mitsubishi... | Answered on Mar 03, 2015
Usually solved by replacing the DLP chip (Google it) they cost around 180. If you have a couple hundred more I'd just go buy a Samsung LCD smart tv.
Mitsubishi... | Answered on Feb 21, 2015
Most tvs like yours flash codes using a blinking method to a number code that can be used to look up in a service manual. You might want to count the blinks then let us know the model number so we can look it up for you.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Mitsubishi... | Answered on Nov 14, 2014
Mitsubishi WD-65735 Television Logo
141 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
fix pixels tv screen
  • Televison & Video
