No 24 volts dc output X520 of power supply. I checked X610, X615 and X660 2.5A fuses and its OK. Could you help me?
SOURCE: T.V. wont turn on
But my freind, If the set had a cold and hot chassis, it could be he is not measuring the voltage from the cold ground and therfore would be a normal reading?
SOURCE: LOW VOLTAGES POWER SUPPLY
Hi. It will be easier to help you if you tell us the make & model of your tv set.
SOURCE: 2 tv to repair
You can check any 5v input to the microprocessor and sound is the audio IC whether have any voltage input.You can try to troubleshoot but please be careful.I don't have your model schematics but oher philip models.
Regards
alan
SOURCE: no picture
try resoldering vertical output ic pins, no vertical deflection will shut off picture. may need ic replacing along with electrolytic cap.
