20 Most Recent Philips 20PF5121 20 in. EDTV-Ready LCD Television Questions & Answers
yes it is not fixable.
Philips 20PF5121... | Answered on Aug 01, 2011
Im not familiar with your T.V byt you can get a universal remote control for that just go to electronic store then ask if they have a universal remote for your T.V make sure you memorize your T.V brand and model..
Philips 20PF5121... | Answered on Jul 14, 2011
This is most certainly a capacitor in the power supply that has gone low in value, hence a low startup supply rail voltage. I would be looking in this area. Tell tail signs of faulty capacitors are from their tops bulging up with possible brown liquid discharge, or if their plastic base inserts give first with the pressure, these pop out from the can.
Philips 20PF5121... | Answered on Feb 13, 2010
if the tv accepts 640 x 480 via DVI lead in safe mode, then as long as the tv is set to work in conjunction with the same resolution as your pc by the pc to DVI setting, it must be your pc's graphics driver that is the problem, as in safe mode the graphics vga driver only is loaded and not the advanced graphics options and resolutions, so enabling you to view on an external monitor. You should be able to right click on your desktop, then graphics properties and select either clone/dual or monitor. If this option does not show then you need to go into your graphics cards properties and ensure that an external screen or multiple display; is enabled, depending on your graphics driver.
Philips 20PF5121... | Answered on Jul 22, 2007
Use code search to find out. If a search through all codes stored in your Philips URC fails, try a different one.
Philips... | Answered 3 days ago
Usual instructions.
Turn on the TV.
Find the code(s) listed for your Phillips TV and shown in the instructions provided with your remote. (If you don't have the instructions, look on the remote manufacturer's website).
On the remote, press the "TV" button.
Then press and hold the "setup" button until the LED blinks twice. Then let go (you atr now in yhe setup mode.)
Now enter the one of the Phillips TV code numbers you got from the instructions (or website.) This is often a three digit or five digit code. If performed properly, the LED should blink twice indicating it has accepted the code. (If it did not blink twice, folliw these steps again.)
Now aim the remote at the TV and press power. The TV should turn off indicating its programned properly.
Try other functions on the remote, sound up and down, change channel, etc. If all work, your done. If not there are usually several different codes listed for every TV, just go back and try them all, until you find the one that works all functions.
Philips... | Answered on Jun 03, 2019
Not sure what your asking
Philips... | Answered on May 31, 2019
Google (Philips)(LP 2E AA)(manual) without parens.
Philips... | Answered on May 29, 2019
Hello Jaunius, indicate if the remote control you are commenting on, is an original replacement or if it is a universal remote control, indicates the type, brand and model, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Jaunius, indica si el control remoto del que estas comentando, es reemplazo original o si es un control remoto universal, indica el tipo, marca y modelo, para poder encontrar la mejor solucion posible
Espero tu respuesta
Saludos Franco Dosil
https://www.download.p4c.philips.com/files/h/hts3450_37/hts3450_37_dfu_aen.pdf
Philips... | Answered on May 22, 2019
The identity is printed on the IC.
Philips... | Answered on May 16, 2019
Hello Eric, you should be able to disable the energy saving of your Philips by entering the menu, then choose Picture, then select, Auto Picture and from there enter and select Energy Saving, where you can change the status and achieve greater clarity, all these steps are indicated in the user manual, page 31
I sent you the link to download the user manual
I hope my comment has served you
Hola Eric, deberias poder deshabilitar el ahorro de energia de tu Philips entrando en el menu, ahi elegir Picture, despues selecionar, Auto Picture y de ahi entrar y selecionar Energy Saving, donde puedes cambiar el estado y lograr mayor claridad, todos estos pasos estan indicados en el manual de usuario, pagina 31
Te envio el link para que descargues el manual de usuario
espero te haya servido mi comentario
https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_aen.pdf
https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_lsp.pdf https://www.download.p4c.philips.com/files/6/65pfl5602_f7/65pfl5602_f7_dfu_lsp.pdf
Philips... | Answered on May 02, 2019
Philips 20PF5121 20 in. EDTV-Ready LCD Television Logo
7 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips 20pf5121 58 problem very long
  • Televison & Video
