Ice maker stopped working, makes a buzzing noise. refrigerator is two years old, we use ice maker several times a day, we have a three year old grandson who is fond of ice water. We checked where the ice drops into it and it's clear.
thank you for your fast response, I will call the manufacturer today. Thanks again. J.Ferrsthank you for your fast response, I will call the manufacturer today. Thanks again. J.Ferrs
You can't post conmments that contain an email address.
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Did you get an error message? We have turned our ice maker off, left it off for about a week, then turned it back on. Some part inside freezes and, so far, this method has worked.
I think you are having the same issue that I am having. My noise is being caused due to ice build up around the fan inside the freezer. There is a switch when you open the door that causes the fan to shut off, hence the reason the noise stops when you open the door.
I pulled the cover (just below the ice maker) and removed the ice that had built up. Only problem is that after three days the noise is back. I think there may be a bigger problem that is causing the ice to build up around the fan.
Hello Welcome to fixya. I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short ! I would get service rather than take a chance on electrical fire. Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you. Huuum Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
