When trying to set print properties, the dialog box does not display correctly, i.e I can no longer see the entire words "Basic" or "Advanced" settings. The dialog box appears to be "cut off" on the right hand side and at the bottom. Had this problem a few years ago and seem to remember that it was related to the size of font somehow, and it was solved. Unfortunately, I cannot quite remember how. Thankyou for any help. Kind regards, Jeni Whitaker.
SOURCE: printing an envelope in cs3 on an epson stylus photo r1800
You can try using Microsoft word in printing on envelopes, it is easier. On my MS word>tools>letters and mailings>envelopes and labels>click on feed and use the fourth from the left option.
Load the envelope at the right side of the printer> the envelope flap should be on the left facing the printer.
SOURCE: Setting Paper Size in Epson Fx-1170
Use the personalized paper size, and set the wide an lenght of the paper you are using.
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
SOURCE: Epson Stylus DX6000 only printing half pages
try to perform a cleaning cycle, if your running on windows just go to the control panel look for printers and faxes, find your printer icon then right click once left click on printing preferences, left click on the maintenance tab then click on head cleaning for about 3 to 4 times in a row. then check for a test print and see if it still persist.
