Epson Stylus C64 InkJet Printer Logo
Question about Epson Stylus C64 InkJet Printer
Re Previous message of 25.10.2015
Have noticed that I was originally using T 443 and T444 Cartridges. Original boxes state For use with 'Epson Stylus C64 New boxes state 'C64' Could this be the reason. Wrong boxes? Carrier which contains cartridges jammed
Posted by Peter Lawrence on
Indrany
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
If you were using T 443 & T444, you should use the same cartridges and if you use the wrong ones it would jam and cause serious damage. So be careful and use the correct cartridges. If you are not sure take the old cartridges and show them to the dealer and he will be happy to show you the correct ones!
Posted on Nov 16, 2015
4 Related Answers
Anonymous
  • 11 Answers
SOURCE: Printer won't recognize cartridges
In my opinion, the Epson series has a problem with their printheads assemblies as they do get clogged too easily. I've experienced this much too often. I do believe that the printheads can be replaced, but it's less of a hassle to just buy a new printer.
Posted on Mar 22, 2009
Anonymous
  • 34 Answers
SOURCE: Epson stylus c64. Replaced low ink printer
1) Unplug the power cord, wait 30 seconds, then plug back in.
2)Did you follow the directions exactly when replacing the cartridge? Did you peel off the protective film?
Posted on Jul 03, 2009
Anonymous
  • 5 Answers
SOURCE: placed 2 refillable cartridge in epsonstylusnx110 not being read
Had the same problem, just pull all of the cartridges out, then reseat them, for some reason this fixes the problem. At least it worked for me.
Posted on Jul 27, 2010
Anonymous
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
2answers
Why won't my Epson NX130 work after replacing one ink cartridge?
you didnt hold your tongue like this :P
will need a lotta more info on this exactly
errors ,
try this reset prog from epson
Epson Ink Pads Reset Utility
Epson printer will not print any copies. I get the message "change cartridges 98/99." I did change both cartidges and can't clear the message and print copies.
i assume that everytime you try to print you get the same message. i sometimes get cartridge unrecognised on my epsom. I have to remove the cartridge, wipe the chip on the cartridge and reinsert.
If this doesnt work please specify printer model and if using original epsom cartridges.
2answers
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Two Cartridges of 4 Not Recognized (new, empty-chipped)
No matter what you do, it will not recognize it.
Brother and Epson's require original epson ink.
Good Luck.....
Epson Stylus DX8400 empty ink cartridges but actually new
Sometimes there is a coating on the chips (even original epson ones!) - Old wives tales say dont touch the chips with your fingers - but take the carts out one by one and wipe your finger over the chips (1 finger for one chip - dont reuse the same finger on a different chip)
Reinstall them and that worked for me on a dx4500 with original epson carts in
Epsom Rx620 states use originals for ink cartridges
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
The RX500 prints only one color or two
See my previous posts about intensive cleaning and you should be good to go again: http://www.fixya.com/support/t138226-printer_not_printing
3answers
INK CAPACITY DISPLAY
This seems to be a "feature" of this printer with compatible cartridges although I'm sure it wouldn't be possible to get Epson to admit it. I have seen the same thing on other R265s and I haven't found a solution a yet. As far as I know, it doesn't affect printing - as long as there's actually ink in the cartridges it will print, despite what the Epson Status Monitor says, but YMMV.
Top Epson Office Equipment & Supplies Experts
Mehandi Husain ...
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
