20 Most Recent Epson Stylus C64 InkJet Printer Questions & Answers
If you were using T 443 & T444, you should use the same cartridges and if you use the wrong ones it would jam and cause serious damage. So be careful and use the correct cartridges. If you are not sure take the old cartridges and show them to the dealer and he will be happy to show you the correct ones!
Epson Stylus C64... | Answered on Nov 16, 2015
Goto>start>setting>printer and faxes>select the printer>Right click it make it online and set as default printer.
Epson Stylus C64... | Answered on Nov 11, 2015
try to go to epson support you can down load software there
Epson Stylus C64... | Answered on Oct 10, 2010
1. Check whether power is on.
2. Remove and reconnect usb cable.
3. Reinstall the driver after uninstalling the old one.
4. Check whether the catridges are emptly or clogged and replace if necessary.
Epson Stylus C64... | Answered on Sep 11, 2010
Go to this link: www.epson.com
Point to the area where you live.
Click on "Drivers and Support."
In the "Product Finder" box type your printer model number "Stylus C64" and click "Go."
Click on "Epson Stylus C64."
Click on "Drivers and Downloads."
Choose the operating system from the list of drivers, follow instructions.
Epson Stylus C64... | Answered on Jul 14, 2010
Hi!
the matter is that Epson, apart from the chips was invented so that when the printer takes a certain amount of printed pages (about 8000 or so, in most models), suddenly stops working , the two buttons start to flash and does not walk more.
This is because the ink that they will bring to the cartridges when cleaning heads, going somewhere.These are the waste ink tanks, this is where you stay, and the printer has a meter that estimates when the tank is full and stops the printer to prevent ink overflow and cause an internal short circuit.
How do I unlock it?
To save money and the hassle of carrying it to better manage service yourself. You download the software company that provides ssc, Static Control Components, the following page:
http://www.ssclg.com/epsone.shtml
and the manual for use the program is here traslated onto english
http://translate.google.com/translate?hl=es&sl=es&tl=en&u=http://www.ahorraentinta.com.es/ayuda_ssc.htm you migth choose your printer model and reset it!
Regards
Epson Stylus C64... | Answered on May 13, 2010
You could try a couple of things - firstly, check to see if there are any foreign objects stopping the cart from moving - this happens regularly, even lollie wrappers can stop it! I once found a comb in a printer!
Secondly, you could try unplugging the printer entirely, turn upside down and give a firm shake, this will assist in clearing debri.
Or finally, Phone 0800 2 EPSON (NZ number)
I hope this helps some of you who are frustrated and ready to throw out your Epson printer. Great forum on the web.
Problems like yours. This is the only advice I can give you. Try it.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Epson Stylus C64... | Answered on Apr 07, 2010
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
Epson Stylus C64... | Answered on Apr 03, 2010
Found this on the web . It has alot of good solutions.
http://www.fixyourownprinter.com/?search=forums&q=EPSON+C64+PRINTER
Thanks and Good Luck.
Epson Stylus C64... | Answered on Apr 01, 2010
you can download your epson c64 from here
Click here to Download
select your operating system then download....
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Epson Stylus C64... | Answered on Mar 25, 2010
Hi Yes you can try cleaning.
Ok it got to be the heads blockage
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
All The Best: Pineworks
Epson Stylus C64... | Answered on Feb 01, 2010
I find by leaving the printer on stand -by it not use as much ink dont swich your priner off, because every time you swich in on it will star cleaning the heads on your printer and that will use lots of your ink up
Epson Stylus C64... | Answered on Jan 27, 2010
is Ink dryed on print-head need to "clean heads" cicle, use a printer key (feed) pressed more of 5 sec, or printer driver as "Clean Heads icon"
Epson Stylus C64... | Answered on Dec 25, 2009
You do not need the CD.
You can download the drivers from EPSON.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23952&infoType=Overview
Epson Stylus C64... | Answered on Dec 06, 2009
Epson Stylus C64 InkJet Printer Logo
42 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
install epson stylus c65 inkjet printer
  • Office Equipment & Supplies
