20 Most Recent Epson Stylus C60 InkJet Printer Questions & Answers
Unplug the printer from computer, then Unplug the printer from wall when the carriage is all the way to the left, then manually slide it to the area where you can open the ink cartridges, pull all ink cartridges out, close cover and turn printer on. Printer should now be acting as it should.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Epson Stylus C60... | Answered on Jun 07, 2017
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Epson Stylus C60... | Answered on Jun 01, 2015
the sensors cant see paper on the perforated part/side.
same goes for transparencies, the printer can't see it
Your printer supports the following media types:
Epson Bright White Paper
Epson Iron-on Cool Peel Transfer Paper
Epson Photo Paper Glossy
Epson Photo Quality Self-adhesive Sheets
Epson Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-sided
Epson Presentation Paper Matte
Epson Ultra Premium Photo Paper Glossy
Epson Stylus C60... | Answered on Dec 28, 2014
Power off your printer, open the cartridge lid; take out the cartridge and put them back again.
Power on your printer and check whether the red light still flashing?
For further assistance, you can also avail our technical support services by visiting our website: http://www.vtechsquad.com.
Epson Stylus C60... | Answered on May 20, 2013
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Epson Stylus C60... | Answered on May 10, 2011
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
download here
i hope this helpfull
thanks for using fixya
Epson Stylus C60... | Answered on Jan 27, 2011
there should be an option in the printer properties to do that in the control panel
Epson Stylus C60... | Answered on Dec 23, 2010
Yes. Go to the printer's icon and double click to open. In this window you can cancel all print jobs and ques.
Epson Stylus C60... | Answered on Nov 01, 2010
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Epson Stylus C60... | Answered on Oct 21, 2010
Epson printers are built with a print counter, the company has predefined a maximum print no. for each model, If your printer is an old one,this could be a possible reason. If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
Epson Stylus C60... | Answered on Sep 28, 2010
Double check to make sure the packaging material is removed and that the cartridges are inserted properly.
Epson Stylus C60... | Answered on Aug 23, 2010
That depend on printer drivers for operating system non on Laptop model, so you need to instal appropriate drivers for that printer.
Epson Stylus C60... | Answered on Jun 27, 2010
Epson Stylus C60 InkJet Printer Logo
192 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
printer not used 3 4 months while
  • Office Equipment & Supplies
