How do I read the graduations on the purifier control & what do the 1 or 2 red plate settings tell me?
The graduations are incremental for your ozone output for the purifier control. Generally, the machine can put out enough ozone to cover 3000 sq ft. (when the control is moved all the way to the right, about 5 o'clock.) Half way should be about 1500 sq ft or 12 o'clock. For general air cleansing, you should set the purifier control to produce enough ozone so you smell it when walking into the room (after home) for about 30 seconds. The ozone smell should disappear after that. If it lingers, you've got it set too high. For more severe odor control you can set it higher but remember that some of us are more sensitive to the odor no matter what the setting. It may need some adjustment based on your individual preferences.
I'm confused about the 'red plates' as you mentioned. The original machine comes w/ 2 ozone plates (made of glass) and doesn't produce ozone when one of the plates is removed. I'm guessing that the lines may tell you when you're engaging both plates to work, i.e. more ozone being produced & blown into the room or less only calling on one plate to produce ozone. If you send me a close up pic of the control panel I may be able to tell you more.
