Sharper Image Ionic Breeze GP SI720 Air Purifier Logo
Question about Sharper Image Ionic Breeze GP SI720 Air Purifier
I need an ionization wire for my ioninc breeze quadra air purifier where can I find one?
Anonymous
    New Friend:
  • 3 Answers
Any system using electric currents are deadly OZONE producers if your ozone producing machine is broken pleas don't fix it replace it look for any system with a filter not a electric current burning all the dust
Posted on Jun 30, 2010
Lynn Kent
    New Friend:
  • 23 Answers
The amount of ozone is negligible, and is not harmful. Answer the question and stop preaching.
Posted on Mar 21, 2015
tip
Sharper Imaage Ionizers
Ionized air purification systems have been proven to be ineffective for cleaning the air. These reports have been published by Consumer Reports as well as the EPA. Sharper Image filed a lawsuit against Consumer Reports and lost. They were ordered to pay Consumer Reports legal bills as well.
Sharper Image issued a recall on all Ionic Breeze Ionizers and filed for Chapter 11 at the same time.
Ionizers have been proven to create an ozone that is harmful to anyone with breathing problems.
Here is a link to the EPA report
Here is an article from CNN.com about The Sharp Image
Support for Ionic Breeze isn't possible since Shaper Image has recalled the product.
Your best bet to keep the air clean in your house is to use a hepa filtration system.
3helpful
2answers
I have si 637 quadra. cleaning the unit both little thin plates at the end of filter fell off. the unit works. how important is repair this ?
If you're talking about those little plastic tabs at the bottom, they aren't important. Their job is to wipe the ionizing wires when you take the grid out or replace it.
I believe that the motor on my Ionic Breeze unit is broken. Can I replace it??
Ionic breeze units don't have motors. I thought they just moved the air by ionization.
The unit might need to be cleaned. Check you owners manual or the manufacturer for instructions.
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
1helpful
Ionic breeze model S1637 needs cartridge brushes that clip in on the bottom end (this model has two ) where can i purchase these? regards, jim
You might be able to pick up spare parts if you scour eBay long enough.
2answers
Cleaning light stays on
I have the same problem and haven't been able to fix it. However, others have had the same problem and have posted their solutions. The sizzling sound is caused by electrical arching between the plates and one or both of the two tungsten wires that are run parallel to the plates (if you turn off all the lights and wait for your eyes to adjust to the dark before turning on the Ionic Breeze, it's a pretty cool light show!) Here are things found by others to cause the arching and what they did to fix the problem:
  • --dirt, lint, or tiny hairs stuck somewhere (usually towards the top or bottom of the plates or wire, and maybe in the grid contact points). Clean it better. Using canned air can help blow out the problem.
  • --water droplets. Make certain there is no moisture anywhere when you put the grid (plates) back in. Using canned air can help dry hard to reach areas.
  • --burn marks or melted plastic. These indicates a short circuit. Says dnewcombe1: "There is a feeler bracket that guides the two rear thin wires while the cartridge is being inserted. This "feeler" can melt and become disarranged." You can't fix this issue.
  • --build up on the ionizing wires. Clean them. It's hard. I took mine apart and used steel wool.
5helpful
2answers
How to get replacement parts for Sharper Image ionizer?
one of the electrodes broke off the botto of one of my towers.
9helpful
3answers
Where can I have a Ionic Breeze Quadra Model S1637 repaired?
Try this link, pair for $10- http://breezerepair.com/parts.html
1helpful
5answers
Ionic Breeze Silent Air Purifier GP
Ionic Breeze products are no longer being supported because Sharper Image has gone into bankruptcy because the units were proven to be ineffective for cleaning the air by Consumer Reports magazine and by EPA studies. In face they have proven that ionizers can be harmful to use if you have breathing problems.
Here is an article about Sharper Image
Here is the EPA article
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
David Shaub
Colin Stickland
Colin Stickland
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
