Troubleshooting & Support
Hot Topics:
- rci
- parts
- manual
- rci cell...
- display
- rci cell
- reset
- install plate
- ecoquest fresh...
- power
- fuse
- turn
- LCD display
- replace rci...
- perform...
- flickering...
- clean
- replace lamp
- synair g4
- wiring
- replace plate
- replace uv...
- rci plate
- blinking light
- fresh air...
- motor
- transformer
- reset button
- rci target...
- turn unit
- View All »
Problems & Solutions
Fresh Air Model 2.0 by Ecoquest ultraviolet light
Hello. Do you have any error code like "Replace RCI Cell"?
how do I replace the fan motor? also, how do I get
To remove the fan, you need to remove the front grill. Unscrew the 4 screws on the corner of the grill, then remove the grill. The fan can...
I have a FRESH AIR SPECTRUM UVX, air cleaner
Sagan, here's a link where you can find the parts you need. http://www.airpurifierrepair.com/ You can purchase them online. Hope this...
i just replaced the ozone
Hopefully, this is a very simple fix! 1) On the front of the machine, in between the manual controls on the right side, there is a tiny...
Do I soak the rci
No, just rinse the RCI target with warm water. Allow it as well as the purification plate to dry completely before reinstalling into the...
I have an Ecoquest Air
Possibly the 4" white plate with the screen center is not inserted correctly, or it may need to be cleaned or replaced. Open the back...
After cleaning unit, cannot get "perform...
As long as something works, it isn't the fuse. If the machine is totally dead, then it's the fuse. The plate and other components...
My EcoQuest fresh air was working fine over the
There is a fuse (the small square insert at the back of the machine; push it in to release then pop it out.) Before checking the fuse, make...
What is a RCI or RCT cell?
The RCI cell is the "honeycomb" with the blue UV light. This is the normal purifier in the machine. It needs to be replaced about...
need a bulb for ecoquest
The Spectrum is no longer being manufactured/distributed by EcoQuest (now Vollara). We don't have extra bulbs in stock, either, but we...
When I cleaned the unit
I have the same unit. You could be correct. Try taking the unit apart again and remove the display unit. Then go to Radio Shack and see what...
how to replace your uv light in your fresh air
1. Unplug the purifier 2. Remove the two screws on the back cover and remove the cover. 3. Remove the two screws on the the top that hold...
Can I replace the Digital Display on my Fresh Air
You will need to send it back to the company. Call the company 1800 989 2299 and ask for a RMA number.
Getting an error message on
Hi, the error message says " replace RCI cell" You have to order the RCI cells from the company or call this number (336)...
i want to take my ecoquest fresh air apart to
Unplug the machine and unscrew the phillips head screw on the back grill of the machine, that is just above the plug. There are depressions...
Unsolved Problems
when I attempt to turn the unit on, the display...
I hadn`t had the unit on for about 3 months. When I last used it, it was working fine. I cleaned it as instructed but...
how to remove the fan motor on fresh air purifier
Need to replace fan motor. How do I remove the old fan?
fresh air is making a popping sound
We took out some sheetrock and it caused some white dust. It wasn't a big job, but you could see white powder on...
Flashes RCI than normal running screen over and...
It's cleaned, kept clean. It just started flashing back and forth between a normal screen than says RCI. I...
perform cleaning on EcoQuest Fresh Air won't...
I have fully cleaned the EcoQuest FreshAir and reassembled it. I pressed the reset button on the front of the machine...
Replace RCI message will not go away
Replaced the RCI unit & plates. Also checked the fuse to ensure it was still good.
Where can I find wiring diagram for Ecoquest air...
Where can I find wiring diagram for Ecoquest air purifier. Replaced UV lamp and disconnected wires and cannot remember...
The white coating on the RCI Target plate is...
The white coating on the RCI Target plate is peeling off. Is this a problem. I have also noticed that there is a...
Upload a manual for Ecoquest Fresh Air Air Purifier
Specifications
TopKey Features
Full Product Name:Ecoquest Fresh Air Air Purifier
Sq. Ft. Coverage:3000 Sq. Ft.
Quiet Operation:With Quiet Operation
HEPA Filter:Without HEPA Filter
Filter Change Indicator:Without Replace Filter Indicator
Dimensions
Depth:9.00 in.
Height:12.00 in.
Width:12.00 in.
Weight:16.00 lb.
Warranty
Warranty:3 Years
What's your problem?
Fix-O-Meter
45,802
45,802 people have viewed this product
- 580 people asked about this product.
- 183 people found solutions for this product.
- 22 people have added this product.
How to Reset...
Snow throwers
Air Purifier...
