Photography Logo
Question about Photography
Skybags number lock not opening.reset new number
Number lock.reset new number.
Posted by kuldeep kothari on
Subhra Datta
Jun 1 2011 answer is really good . It worked
Posted on Nov 29, 2022
3 Related Answers
Anonymous
  • 784 Answers
SOURCE: I baught a new Skybag
well -- if it is not opening with the digits that you have selected then something may have gone wrong in the lock itself or broke. one thing that you can try is to see if the combo somehow changed due to a faulty disk is to progess the entire combo pack,, by this I mean starting at 000 then 001 -002 -003-004 and so on all the way up to 999,, and after each new number is dialed in try the lock. back in the lock shop I worked at we would get one or two of these a week and it should only take you about 15 to 20 minutes to go through the 1000 numbers. ( hopefully you will get the combo sooner ). now there is a chance that the lock catch is just bound up and if you put in the digits that you picked and press down on the lock latch and try and release it then with the lever - this might snap it back. if both these suggestions fail your next bet is to find a local locksmith and see if they can read the wheels and line things up right and get the lock to open,, most shops will only charge 5 to 10 dollars for this service.
I hope it all works out,
c...
Posted on Jan 01, 2011
Anonymous
SOURCE: VIP Skybag lock combination forgotten.Bag
we took a bag skybag we got a lock free but the lock is not opening wat shal we do
Posted on Nov 20, 2010
ka4iup
ka4iup
  • 4062 Answers
SOURCE: I forgotten my skybag number lock how to open the lock .
You can try to determine the combination by pulling on the shackle and moving the combination wheels until one of them clicks (or feels) different from the other numbers. Do the same for the other two number wheels. Lots of trial and error, but it has worked before.
http://traveltips.usatoday.com/unlock-threedigit-combo-master-luggage-lock-109482.html
Posted on Feb 05, 2015
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
2helpful
2answers
I lost the combination so haven't locked it for fear of not getting it open again
that doesnt sound safe!have you tried emailing the manufacturer with a serial number and model number.to ask for combination.
1helpful
I am able to open the lock with 0000, but it does not reset with new numbers. What am I doing wrong?
The lock must be open/unlocked to reset it. If there is a reset key, you'll also need to insert that according to the directions. These locks are designed so they can't be reset while locked. The shackle might also need to be put in a certain position.
I baught a new Skybag (product of VIP Industriers in India) and set the number lock to my preffered 3 digit nos.On reaching Melbourne from Delhi,I am unable to open my Skybag number lock.Can you please...
c...
Jan 01, 2011 • Garden
25helpful
10helpful
Reset lock on samsonite oyser luggage
i hope you can help me!
i went to change the combination on my locked Samsonite bag and when i closed it it would not open on that number.
i have tried the past number as well as the new one and it still doesn't open. thank you if you can help please it would be appriciated.
Carolyn
17helpful
We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
Try this....
My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
- I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
contained a pdf titled :
- Resettable Combination Cable
(red reset buttons inside)
which is not the cryptoflex 1218 but is compatible anyway.
dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
here are the instructions:
To set your own combination
Your new lock is preset to open at 0-0-0-5 at the factory.
1. Open the lock by aligning the opening combination
number to the Guide Points and pull out the Lock
Post. (Figure 1)
2. Push down the two Reset Buttons simultaneously
with thumb and forefinger, and turn counterclockwise
until it comes to a stop. (Figure 2)
3.You are now ready to turn the dials to set your
secret combination, such as a phone number, birthday,
etc.
4. After setting your secret combination, turn the
two Reset Buttons again by Thumb and Forefinger
clockwise until it comes to a stop and back to its
original position.
5. Verify your new combination before using your
lock. Insert the Lock Post all the way into the Locking
Port but do not turn the dials. Pull out the Lock Post.
Your lock is ready to use.
6.The reset operation is now complete. Repeat
steps 1-5 anytime you wish to change your secret
combination.
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Photography Expert? Answer questions, earn points and help others
