Alpine Air XL-15 Air Purifier Logo
Question about Alpine Air XL-15 Air Purifier
How do I read the graduations on the purifier control & what do the 1 or 2 red plate settings tell me?
I'm not sure how I should read the graduations on the purifier control and wonder what the lines for 1 & 2 red plates tell me.
Posted by Charles Dietz on
erichfaust9
    New Friend:
  • 33 Answers
The graduations are incremental for your ozone output for the purifier control. Generally, the machine can put out enough ozone to cover 3000 sq ft. (when the control is moved all the way to the right, about 5 o'clock.) Half way should be about 1500 sq ft or 12 o'clock. For general air cleansing, you should set the purifier control to produce enough ozone so you smell it when walking into the room (after home) for about 30 seconds. The ozone smell should disappear after that. If it lingers, you've got it set too high. For more severe odor control you can set it higher but remember that some of us are more sensitive to the odor no matter what the setting. It may need some adjustment based on your individual preferences.
I'm confused about the 'red plates' as you mentioned. The original machine comes w/ 2 ozone plates (made of glass) and doesn't produce ozone when one of the plates is removed. I'm guessing that the lines may tell you when you're engaging both plates to work, i.e. more ozone being produced & blown into the room or less only calling on one plate to produce ozone. If you send me a close up pic of the control panel I may be able to tell you more.
Posted on Apr 10, 2014
2 Related Answers
Stephen Lam
  • 670 Answers
SOURCE: we have an alpine air purifier and the plate needs
Take a 1 part ammonia and 1 part water solution and an old toothbrush and dip the brush in the ammonia solution and scrub the metal grid on the plate to remove the deposits. Do both sides and then rinse with water and allow it to completely dry before reinstalling. Hope this helps.
Posted on Nov 05, 2010
Anonymous
  • 18 Answers
SOURCE: What makes the Alpine and Ecoquest Purifier stop
i am aligned with an ecoquest repair center if you would like some help
Posted on Nov 17, 2010
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
My xl-15 air purifier works but it does not blow out air with the purified smell. I think I see people calling it ozone.bthere used to be what looked to be an illuminated orange light behind the fan. It...
Easy. You need new plates in the machine. They cost about $15 a piece. Google 'ozone plates for XL-15' & sources will come up on where to buy them. Remember to clean the plates every 30-45 days w/ 50-50 solution of ammonia & water & a tooth brush on these plates. Dry thoroughly w/ hair dryer before putting back in machine.
1helpful
I have an Ecoquest Air Purifier....I have had it for about three years....it has always run beautifully, although it has not had much use.... today i put it on Sanitize and it simply isn't doing it....It...
Possibly the 4" white plate with the screen center is not inserted correctly, or it may need to be cleaned or replaced. Open the back of the machine and remove the plate. Clean it with a solution of equal parts ammonia/warm water. Scrub gently with a toothbrush or soft veggie brush, rinse well, blow-dry or air-dry. DO NOT use any kind of drying cloth or paper, and avoid touching the screen portion with fingers.
When the plate is dry, inspect it for any burned sections, broken wires, cracks, or other imperfections. If anything appears broken, the plate must be replaced. (Call Vollara, the new name for EcoQuest at 1-800-989-2299 to order. Use #16618 if you need a referral number.)
When you reinsert the plate, make sure the plate is inserted with both the top and bottom of the plate in the "tracks." Also make sure that the two metal contact fingers are pressing firmly on the screen portion of the plate. Look carefully to see if you can detect any loose wires, connections, or corroded components that may be shorting out or broken.
When you power on the machine, if the contact points are receiving power and if the plate is clean and unbroken, you should be able to smell the purifier both on "sanitize" and with the "purifier on" settings. Remember, the air passes in a V from the front of the machine, so if you're standing close, front and center, you may not smell the purifier. High humidity also masks the ozone smell. Also, if the UV/cell is on, you're still getting powerful purification.
Hope this helps.
1helpful
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
3helpful
Fresh air is reading perform cleaning. exactly what does that mean,I cleaned the filter and the plate but it stii reads perform cleaning.HOW
After you have cleaned the filter and plate, reassemble the purifier. Plug it in, turn it on, when the message perform cleaning reappears, press the Reminder Reset button on the purifier to clear the message. Now you are good to go for another 30 days.
3helpful
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Message says Replace Plate
Pat,
the circuit board might be the issue here. There is another possibility.
Sometimes the contacts that connect to the place do not make good contact. You can try to carefully bend the contacts after removing the plate to create a tighter fit. Be careful not to move/force the little bar where the contacts are connected to.
Cleaning the contacts with denaturalized alcohol might work too.
Hope this helps!
Eric
1helpful
2answers
Have HAP422BRC-u Need explantation on the small red window above the name HOLMES does it light up or just a design?
That small red window located ont he fron of the unit is for the infrared remote control that came with your Holes HAP422BRC-U
BULB AND LAMP
I can give you some possibilities. A loose connection, a broken or corroded wire and/or terminal end, dust or moisture on a circuit board, the plate needs cleaning, the contacts for the plate need cleaning, the bulb ballast needs to be replaced, the bulb may not be properly installed, the support posts for the plate need cleaning. These are all I can think of at the moment.
Top Alpine Air Air Purifiers Experts
David Shaub
Marvin
Marvin
Tom Chichester
Are you an Alpine Air Air Purifier Expert? Answer questions, earn points and help others
