SOURCE: Manual for Saeco Vienna Super Automatica machine
I have a manual for type sup 018 if that helps
SOURCE: manual or instructions
http://www.focuselectrics.com/supportdata/L5750_CocoaLatte_CM300_ALL.pdf
Downloads complete manual as PDF. I lost mine too.
SOURCE: No user instructions
Please use the link provided below to download the required manual.
http://powertool.manualsonline.com/manuals/mfg/breville/breville_product_list.html
SOURCE: instruction for proline ce5 coffee machine
I have an instruction manual that I can scan. Email me on [email protected] and i will send it to you.
Steve
SOURCE: Hi We have misplace user guide and our machine is
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say “Descale finished”. Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose “Yes” and push enter so the machine will tell you when you need to descale again.
