Question about KitchenAid KPES100PM Espresso Machine
Need a manual on Kitchen AidArtisan espresso machine KPES100PM, that I can print out Lars
Posted by larsjessen on
Michael Thomas
  • KitchenAid Master
  • 3,051 Answers
HELLO THERE: PLEASE TRY THIS OK? and dont forget to rate this for me it helps me out so i can help you all out more best regards mike User manual KITCHENAID - User guide KITCHENAID - operating instructions ... KITCHENAID, user manual, user guide KITCHEN, KITCHEN AID, Washing : Washing Machine, ... user manual KITCHENAID MACHINE A ESPRESSO ARTISAN - operating instructions , ...safemanuals.com/brand-user-guide-instructions-owner-manual/KITCHENAID - 53k - Cached
Posted on Aug 20, 2009
Broken off black hose in reservoir tank - can I use the machine if I don't use the frother?
You can use the machine forever like that, the black hose is a return hose, it's there so water can return to the tank without you hearing it dribbling into the tank. The clear hose is the pickup hose.
Oct 07, 2013 | KitchenAid KPES100PM Espresso Machine
My Kitchen Aid Pro Line Espresso Machine has stopped heating the water on the espresso side. It still pumps, but it is not hot. The steamer side works fine.
Hi I have posted a service manual and a parts list here
https://rapidshare.com/files/655646388/kitenaid_service_manual_5KES100.pdf
https://rapidshare.com/files/2923830445/Kitchenaid_5KES100_Repair_Part_List_-_8212198.pdf
It sounds like the boiler element or maybe the thermostat. You have to take the top part of the machine off to get a good look at the water boiler.
I have uploaded a not very good strip guide that I got from the internet, I have used it but it makes thing overly complicated to my mind, but here it is anyway.
https://rapidshare.com/files/3189994876/KES100_strip_guide.zip
It has written instruction that relate to two diagrams in the PDF.
May 19, 2012 | KitchenAid PRO LINE KPES100PM Espresso...
Won't stay on
If you mean the switch will not lock on then replace the switch and check for steam boiler leaks while you are there. Steam is the cause of most switch failures in this model.
Sep 29, 2011 | KitchenAid KPES100PM Espresso Machine
I am needing to replace the solenoid valve in my kitchen aid pro line espresso machine. kitchen aid does not carry the part. any idea on where to get it?
Hi I have brought parts for mine from a place in Germany they are happy to ship to the UK but the shipping is quite expensive they have the 3 way solenoid for 51 euros on their website.
here is a link at mediafire.com to a pdf of the web address as it has non English letters this website will not allow me to post it directly also a link to the parts list I posted on rapidshares.com
http://www.mediafire.com/?6utm0xi5wypcqhr
Feb 16, 2011 | KitchenAid PRO LINE KPES100PM Espresso...
I have a kitchenaid KPES100PM espresso machine and every now and then water will start leaking from underneath the machine.
Push the center top of the water tank in as far as you can without breaking it. Do this each time you refill.
Jan 28, 2011 | KitchenAid KPES100PM Espresso Machine
How do you change the gasket in the coffee dispensing part of the KitchenAid Pro Line KPES100PM Espresso Machine? My coffee is smelling like a rotten gasket. Seems to me I should be able to dig it out...
Remove the filter grille with the single cross head screw in the middle, then undo the 2x allen head screws now exposed. It may require some sideways levering with a large screwdriver once the allen screws are out to move the aluminium puck. You really do need to get it out to clean the puck up. Make sure the 4 holes thru the puck are cleaned out properly with a drill and buff all surfaces up with a wire brush. Remove the old brew head seal and clean up where the puck came from then refit the puck and push the new seal into place.
Aug 22, 2017 | KitchenAid PRO LINE KPES100PM Espresso...
Steamer/frother leaks and cannot be completely closed. I have been told that I must replace a rubber gasket on the espresso system. Is this correct?
Not a solution but a note. Kitchenaid got sold off to whirlpool and they almost immediately discontinued this model. I had two of them with the same issue, that of leakinghigh pressure lines. I can't even find an appliance repair facility that will touch this model because they can't get repair parts. Spent a lot of money on two espresso machines that don't work.
Feb 05, 2010 | KitchenAid PRO LINE KPES100PM Espresso...
KPES100PM Espresso Machine - will not make espresso
While I am familiar with Kitchenaid espresso makers, I am not familiar with this problem. I would suggest calling Kitchenaid Customer Service, as you will have options under your Pro Line warranty. Their toll-free telephone number is:
1.800.541.6390.
Jul 03, 2009 | KitchenAid PRO LINE KPES100PM Espresso...
Kitchenaid Espresso maker no longer dispenses hot water from frother
by frother you mean it puts out steam ? if yes then I need to know how long you hold down the button and have you checked the hose in back to see if it has cracks or is kinked?
Dec 31, 2007 | KitchenAid PRO LINE KPES100PM Espresso...
KitchenAid KPES100PM Espresso Machine Logo
779 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
graybeard32301
Ismael Rodriguez...
Marvin
Marvin
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
