Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
Posted on May 16, 2009
How to Transfer Files from Nomad IIc to PC
How to Transfer NomadIIc Files to PC
3helpful
When it the zen is turned on it says firmware
Had the same problem and nearly went nuts trying to fix it. Here's what I did:
1. Uninstall all creative driver & creative software.
2. Uninstalled Windows Media Player 11 (Rolled back to WMP 10) and restarted PC.
3. Uninstalled Windows Media Player 11 Runtime and restarted PC.
4. Downloaded and Installed the latest free version of Winamp from http://www.winamp.com
5. Connected my A/C Power Cord to my Nomad Jukebox then connected my Nomad Jukebox via USB cable to the Computer.
The computer should then recognize the Nomad Jukebox as "Found New Hardware" then "MTP Device" and lastly "Your new hardware is installed and ready to use.
6. If you haven't already, go to the creative website and download the Creative Zen Xtra PlaysForSure Firmware 2.10.03 and save it to your computer.
7. Run the Firmware (Make sure Nomad Jukebox is connected) and at this point the Computer should recognize the Nomad Jukebox and begin the upgrade.
After your upgrade is complete, You can go ahead and re-download Windows Media Player 11 and it will recognize the Nomad Jukebox.Not sure what version of windows you have, but I have two computers, one with windows xp and the other has windows 7 and Im able to transfer music perfectly fine with Windows Media Player and RealPlayer on both computers. I hope this works for you. Good Luck!
Creative Labs Nomad Jukebox 3
Hi J...welllll....I dunno what kinda internal damage your player may have suffered, but let's try a couple of exercises and see if we achieve success. 1) Have you tried resetting your player? To reset your player, insert the end of a paperclip into the Reset Hole. Under normal circumstances, resetting your player will not cause any data/file loss. 2) Click on the URL below, and download the latest appropriate software for your OS, also download the latest firmware for your player. My intention here, is to attempt to sync your player with your computer, which will allow you to control your player via your pc, and ultimately enable you to transfer your files from player to pc. However, success using this theory is relying on a simple loss of your Firmware/BIOS information contained in the EPROM from the jolt. http://us.creative.com/support/downloads/download.asp?MainCategory=213&nRegionFK=&nCountryFK=&nLanguageFK=&sOSName=Windows+XP®ion=1&Product_Name=NOMAD+Jukebox+3&Product_ID=296&modelnumber=&driverlang=1033&OS=10&drivertype=0&x=33&y=12 Please update your post with specifics on any failures or progress....meanwhile...I'll toss your dilema around in my head until I learn of your status......good luck my friend
My creative zen nomad jukebox usb 2.0 will not turn on its been charging for ages and when i press the reset button the logo come up but i can not do anything more than this, please help.
hi my son has old nomad jukebox zen nk it comes on but pc does not recongize drive, want to transfer music to pc or sd card how can i do that would i need some type of software and how can the pc see what device it's going to when i put in usb cord to mp3 to pc?
Loss of music library
Uninstall everything from your PC, reboot, reinstall driver and the Explorer (I do not use MediaSource, only the Explorer).
If it didn't work out follow these steps:
1. Uninstall Creative Media Source and all related software.
2. Install the driver. In the installation CD the driver is usually in \Drivers\English
3. Turn on the Nomad an connect it to the PC.
4. Install MediaSource(the program requires that you have the nomad connected while installing)
5. Install MediaSource plugin
6. Try transferring files.
If you?re still running into problem know that there are other programs capable of handling MediaSource?s functions, such as - Portable Audio Devices Power Toy , NomadSync, Real player, and there?s also a Zen plugin for the Winamp.
Creative zen nomad
Lock/hold may be engaged
Drivers
No Drivers exist for this MP3 Player on Vista. At least according to creative.com
I can not transfer files of 700 Mb
maybe a software will need to upload a file..
Nomad Jukebox 3
If you plug the USB cable into your PC and turn it on what happens?
2answers
Can?t transfer files using the Creative Media Source Organizer. I?m getting the following error: ?Error: Unable to create file. Restart player and try again." Tried restarting the device, but no use....
Uninstall everything from your PC, reboot, reinstall driver and the Explorer (I do not use MediaSource, only the Explorer). If it didn't work out follow these steps: 1. Uninstall Creative Media Source and all related software. 2. Install the driver. In the installation CD the driver is usually in \Drivers\English 3. Turn on the Nomad an connect it to the PC. 4. Install MediaSource(the program requires that you have the nomad connected while installing) 5. Install MediaSource plugin 6. Try transferring files. If you?re still running into problem know that there are other programs capable of handling MediaSource?s functions, such as - Portable Audio Devices Power Toy , NomadSync, Real player, and there?s also a Zen plugin for the Winamp. Good luck!
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
