Hello i request you to take this manual...read it and check your problem related this issue
http://pctechsva.com/Documents/VIZIO_VX37L%20HDTV.pdf
Un-plugg it and plig it back. if this doesnt work, call vizio Toll-Free:888.849.4623
If the TV remote is not responding you need to do a code search and then retrieve it.
Manual Code Search: (for TV)
1) Press and hold "Code Search" button
2) Press and release the "TV" button
3) Aim at TV, then press and release the on-off key continuously until the TV shuts off (you may have to do this 200 times!, according to the manual)
5) When the TV turns off, press "Enter" key to store the code
6) Use Code Retrieval method to identify code for future use
Code retrieval:
1) Press code search until indicator light illuminates
2) Press the TV key
3) Press and release the code search key The indicator light turns off.
4)Starting with "0" press the keys in order until the indicator light blinks.
5) The number that causes the light to blink is the first digit of the code.
6) Repeat step 4 until you have all three digits of the code.
Make sure that the TV Signal is set correctly.
Thank You
The
power up test sequence has detected a key in the operated condition.
The power up test
sequence
is performed every time the unit is turned on (powered up). This test
is performed
because
a permanently stuck key will inhibit the correct operation of the
unit.
Possible
Causes
1.
A key on the display housing is permanently stuck in the operated
condition.
2.
One of the upper PCA's keypad interface chips has failed.
3.
Liquid (perhaps perspiration) is present on the surface of a touch
sensitive display.
Possible
Remedies
1.
Remove the keypad connector cable from the upper PCA. Restart the
power up sequence, if
the
ERROR 5 is no longer present, the keypad is the cause. The keypad is
typically part of
the
display housing. Replace the display housing to correct the problem.
2.
the
ERROR 5 is still present, the upper PCA is the cause. Replace the
upper PCA to correct
this
problem. Most upper PCA's are provided without software. Therefore,
the software (chip)
must
be removed from the upper PCA being replaced and re-installed on the
replacement
upper
PCA.
3.
Wipe the surface of the touch sensitive display clean of all liquid.
Restart
the power up
sequence,
if the ERROR 5 is no longer present, the liquid was the cause.
The
The power up test
sequence
is performed
because
unit.
Possible
Causes
1.
condition.
2.
3.
sensitive display.
Possible
Remedies
1.
the
typically part of
the
2.
the
this
the software (chip)
must
replacement
upper
PCA.
3.
Restart
the power up
sequence,
The
The power up test
sequence
is performed
because
unit.
Possible
Causes
1.
condition.
2.
3.
sensitive display.
Possible
Remedies
1.
the
typically part of
the
2.
the
this
the software (chip)
must
replacement
upper
PCA.
3.
Restart
the power up
sequence,
The
The power up test
sequence
is performed
because
unit.
Possible
Causes
1.
condition.
2.
3.
sensitive display.
Possible
Remedies
1.
the
typically part of
the
2.
the
this
the software (chip)
must
replacement
upper
PCA.
3.
Restart
the power up
sequence,
First the Tv is a Vizio VX37LHDTV, Second: When the TV powers on it displays a sequence of video test patterns over and over again. It never shows the normal V1, V2, Component etc.. screens. The remote will only turn the TV On/Off. The Manual keys will only turn the TV On/Off. How do I turn off the test patterns and resume normal display?
Any experts on Vizio LCD HDTV's please read my previous posts and reply if you have an answer. Thanks
