Question about Vizio E470VL 47 in. HD-Ready LCD TV
Vizio refurbished 47 Inch flat screen TV, Model E470VL. After a power outage, the tv comes on to a seemingly test pattern screen, but will not boot beyond that. There is no sound. Sometimes the boo
Five month ago, I bought a Vizio refurbished 47 Inch flat screen TV, Model E470VL. After a power outage, the tv comes on to a seemingly test pattern screen, but will not boot beyond that. There is no sound. Sometimes the boot up word Vizio will briefly appear on the screen. In any event the screen shows the test pattern effect for a few seconds and a black screen appears. The vizio power indicator remains lit. I am new to LCD tv technology, but I suspect the main board is the problem. I can upload a picture of the screen if needed.
Anonymous
    New Friend:
Sounds like you had a high voltage power surge just before going out
Are u using a high grade reference center or surge stage 2 or 3?
Posted on Nov 28, 2011
  • Anonymous Dec 11, 2011
    I researched the problem and repaired it myself. It was the main board. I purchased one from Shop Jimmy (shopjimmy.com)
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers ยท Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
What is wrong with my vizio e470va 47 inch it has sound but no picture
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
No picture or sound
First of all check the power cable is connected to both the TV and power outlet correctly and that no fuses are blown.
I got a 47' vizio hdtv. i get power to it put wont turn on
In order to ensure, it is not caused by the input device, connect a DVD player and see. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Vizio 47
It sounds that the main board has got faulty. Seek check support.
1helpful
Vizio E470VL - What is screw size for mounting stand?
I don't know if the screws would be different depending on the tv model, but on a Vizio Model E470VLE 47" LCD HDTV, the screws for the base are M4 x 30ST.
How do I turn my Vizio E470VL CC off?
CC is either coming from the box or the set--if grayed out on set means that option is closed---you have to look for it in the set and the BOX menu--have you tried removing box from use?
4helpful
Panasonic plasma tv (47 inches), inputs not working
My 42 inch is powering on but is blank on the screen ..
Vizio E470VL 47 in. HD-Ready LCD TV Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
