The printing seems to leave gaps in solid areas and flakes off, please help!
SOURCE: Samsung CLP-315
try to do this set of instruction & solution:
SOURCE: Samsung CLP-315 system error
Low heat error comes from the fuser unit, there is a thermostat on the fuser change that and it will work
SOURCE: how to print miror image
After you select the image to print the printer dialogue box opens, click on preferences and tell the printer to print a mirror image. It's set in your computer and not at the printer.
SOURCE: Hi. My Samsung CLP 300 Laser is playing up. It
The problem you are experiencing is a common problem with this printer. What happens is over time as the printer is used, toner or developer builds up a film on the developer blades. The developer blades meter the amount of toner that the printer puts on the paper to make the image. As the film builds up, less and less toner makes it to the page causing the image to become faint. The black developer blade probally is clogged.
This can be fixed two ways. The easiest and most expensive is to buy a new imaging unit for about $100+. The second is to disassemble your imaging unit and clean the developer blade(s). This can be done in about 30 minutes. I have posted instructions in my Tips section.
SOURCE: Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
Testimonial: "Thankyou"
