If you push the power button and the machine will not turn on and it a newer machine there is a reset button on the side of the boiler that needs to be pushed. This will get you [power again. If the machine is older than 3 years you probably need a new board or power filter.
SOURCE: grinder setting i
0 is the finest setting. If you read the manual, it advises to adjust your grinder ONLY when the grinder is actually working. Also, you should only adjust it gradually from one setting to the next (ei. from 2 to 3), and wait about 5 cups before adjusting the setting again.
SOURCE: Manual for Saeco Vienna Super Automatica machine
I have a manual for type sup 018 if that helps
SOURCE: How do I change the aqua filter in the Saeco
it is not a filter but a water softener and no need to replace. You need to pass thought it 2 spoon full of salt desolve with water and then flush it with water for 15 min until the salt will be cleaned. You can do this one time per month so to avoid any scale build inside the machine.
SOURCE: My Saeco Vienna Black Automatica
Your grind is to fine. Turn the big knob in the bean hopper up 4 clicks and try again. It could be oily beans which would require the same solution.
My macine, when all clear with coffe and water, the lamp of coffie beans are blinking,the macine dont start
