[Canon Printer Error Code b200] Printers has now become a compulsory necessity that belongs to any company, including at home. Each consumer wants his computer to function quickly and help him complete his job in very little time. Canon printers allow users to reduce their workload through high-quality printing, scanning, and high speed. It is an electronic system and the problem with it is very clear.
The Canon printer error code is still the most frequent problem that can be encountered by a Canon printer user. Due to many of the issues such as electrical issues such as resistor impact on the mainboard or over-heating this support code error may cause.
Solutions that Fix this Error:-
1. Start by removing and reinstall all of the ink cartridges.
2. Disable the print head and clean all the golden contacts on the print head itself completely. Make sure the rope cable connector is securely plugged into the print head itself when the print head is reinstalled (this typically applies to older models).
3. Wipe it thoroughly by scrubbing all the ink out under the hot water tap when the print head is out. This video could help-Cleaning head print
Full Solution- Canon Printer Error Code B200
SOURCE: Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
SOURCE: how to fix error b200 on my canon pixma mp620
Replace your printerhead will do the trick. Had the same issue with my MP980
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
SOURCE: Canon Printer Pixma MP540 with
Try to press down on the sponge to get it to work again. It may be a waste toner issue, which generally is repaired at an authorized service center for canon by contacting 1-800-OK CANON or logging on to canonusa.com.
Good luck on this.
How do i reset the printer to factory default ? or make it forget it's settings? Many thanks for your help guys!
