The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
dE indicates a door lock error. Turn off and then unplug the washer to reset the machine. Press and hold the Start/Pause button button for 5-10 seconds. Connect the power cord. Turn on the washer. Open and close the lid to see if it closes properly. Try to run the washer through a cycle.
On some LG top-loading machines, the error is simple to fix. These LG top loaders used a magnet in the front of the lid that to be in place to trigger the lock. When the magnet breaks off or is misplaced, the dE error will occur. If you find the magnet in the washer, replace it in the lid. If you don't see the magnet, get another one. Keep the magnet in place with duct tape.
On other LG washers, the problem is the door not being aligned with the lock, the lock assembly or the electronic control not getting the lock message. Make sure that the lid is closing properly. Bent hinges can cause the issue. Check the latch assembly and the wiring between the latch and the control board. To check the latch assembly, you may need to remove it from the washer. Check the circuit with a multi-meter to ensure that the switch gets power. Replace either if faulty. If the latch assembly and wiring are good, then the control board may need to be replaced.
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Telescope, Im assuming your model starts with 417.44092, Kenmore made by Frigidaire. You have the best model with the digital display. Try unplugging the machine for 5 minutes to see if you can reset the board. If that doesn't work put it into a test mode by doing the following: Turn the dial to drain spin, press cancel to turn off the led's. Within 5 seconds press and hold the options and pause/cancel together for 5 seconds. All the led's should light. Now by turning the dial 1 click at a time clockwise you are going to test the following. 1rst click- hot water solenoid 2. bleach solenoid 3. Bleach and wash water solenoid 4. door lock solenoid activates 5. door lock solenoid de-activates. 6. the washer will fill and tumbe. 7. washer will fill and spin 8. drain pump and door lock will activate and washer will go in high spin. 9 clicks from the start, the last error code will be displayed. To clear the error, press and hold the options and cancel buttons for 3 seconds. To exit the test, just unplug the washer for 5 seconds. Sometimes these electronic boards just get a glitch and have to be reset. Make sure that the dispensor door is shut all the way. Try these things first...Catriver..post back.
