Go to www.belkin.com/support download the latest firmware for your router model number type 192.168.2.1 in the url box in your browser open the belkin router page left down colum bottom under utilites you can find firmware upadate->browse and locate your downloaded file and upgrade and under wireless->channel ssid->change channel to 11
that sounds like a video card error. if you can disassemble the notebook, check for loose connectors, particularly the connector that goes to the screen.
1. Press the bottom left button(MODE) to put on Time mode. 2. Press the LIGHT button (ADJUST/LIGHT) for three seconds. 3. Press the MODE button to select what you wanna change, be it hours, minutes, or seconds. 4. The upper right button (START/LAP) is to move a number up, the bottom right button (STOP/RESET) is to move a number down. 5. Press the LIGHT button to finish.
You may try typing admin on the username field. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left
side of the page. On the Wireless page, you will see the wireless
settings set in the router. You may also enable the wireless security
on that page if there is not security enabled yet.
hello,the buttons are numbered 1-4
clockwise-top right button #1
bottom right button #2
bottom left button #3
top left button is #4
in normal time push #3,then #1 to start and stop lap time.
for lap time press #2 while chronograph is running,it keeps running while lap time is displayed push #2 again to return to chronograph time display,to clear push #1 to stop then #2 to clear.
If you move your laptop screen to were it works sometimes and doest work other, it sounds like it could have a loose connection in the ribbon cable. Most laptop lcd screens are connected to the main board through a brown looking ribbon cable. if this cable has become loosened, then yes it can be a DIY type job.
if you attempt to take the laptop apart, i sugguest you keep a record of what type screws go where.
Set the chronograph. Push the bottom left button until you see the word "CHRONO" on your watch. Press the top right button to pick "Lap" or "Split." Press the top right button to start or stop the timer.
Press the bottom left button to see your lap or split time. Press the bottom left button to pause the timer. Press the top right button to start again. When you're finished, press the bottom left button to stop timing. Push it again to reset it your chronograph to zero.
