Question edited for clarity and better written English.
Question moved from Washing Machines to a Tanning Bed Category.
Usually, if a single tube goes out, only that tube is affected. If the ballast fails, they all go out. You can test by swapping parts from the upper to the lower, testing between each replacement.
It is not a particularly well known make here in Canada.
Klafsun.comhttp://www.klafsun.comWe've thought of everything you need. A huge comfortable tanning surface that pampers even the biggest customer. A powerful new generation of lamps that..
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
do you have a dial up modem installed in the system's pci slot? try removing it and see if it posts then. if it still doesn't post (show bios screen) then try using a known good stick of ram. if it still doesn't display then chances are its the power supply.
3 times blink shows lamp cover is removed or not installed properly on TV. Please take out lamp inside TV and check, seems its broken as you heard loud pop. Thanks.
"FF" or a blinking light will display meaning “Fault Found”. The “fault” is in the amount of power available to the blanket, mattress pad or throw.
There are several causes to this problem: 1. Bedding product is plugged into an extension cord, surge protector, power strip, or not plugged into a direct wall outlet. 2. Bedding product wasn't plugged in properly.
To FIX this problem, do the following to reset your bedding product:
1. Unplug the power cord from the electrical connection. 2. Unplug the cord from the actual bedding product itself. 3. Re-plug the cord into the bedding product. Make sure the connection is secure and complete. 4. Re-insert power cord back into a wall outlet.
If the 4 steps above are not followed in order, the bedding product will not properly reset.
Please research this more before asking a question! There are 4 caps in the DM module that need to be changed. It DOES require some technical skills and soldering experience. If you still have not found the answer to this problem, let me know
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
