20 Most Recent Mitsubishi WS-65513 65" Rear Projection HDTV Questions & Answers
Your going to need to measure the various power supply voltages to see if its a bad main or power supply board
Mitsubishi... | Answered on Nov 08, 2017
If you have the time you might just want to measure them with a cap tester. It is not uncommon for a bad capacitor to look beautifully new.
Mitsubishi... | Answered on Aug 26, 2017
Misaligned pin cushion adjustment, of damaged component/s at this stage circuit inside. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts.
Mitsubishi... | Answered on Jun 05, 2017
Take it of letterbox and put it on full ratios
Mitsubishi... | Answered on Mar 03, 2017
resolder the 9 vol;t regulator Ic right behind the input board in the back
Mitsubishi... | Answered on May 05, 2015
If you have to change one or two bulging capacitors, then you may as well change them all. They won't cost much and would be available in any electronics store. Just make sure the values in uF as WELL as the voltage and temperature ratings are the same. All the info is stamped on the capacitors jackets.
Mitsubishi... | Answered on Nov 17, 2013
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
Mitsubishi... | Answered on Nov 13, 2013
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Mitsubishi... | Answered on Oct 03, 2013
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
295 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
green power light flashes continuousely
  • Televison & Video
