If i use progressive it only show me a blank screen on tv. but if i switched it to interlaced i can access ny psp on tv nut i cannot play the UMD. What should i do?
does it mean that i cannot use it even if i downloaded the ner version 5.03?
Is there any option for this one so i can use it with my tv?does it mean that i cannot use it even if i downloaded the ner version 5.03?
You can't post conmments that contain an email address.
Re: If i use progressive it only show me a blank screen...
Your tv does not support progressive . With interlaced you cannot play games on tv. Most or all hdtvs have progressive scan, at the same time most standard def tvs do not.
I read the info for the update and it looks like it's just a security fix. I have heard of people using standard a/v cables to play games on tv. However it was through homebrew. You will need to look that up on google if you want to learn more.
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video Compared to interlace video, progressive scan video effectively doubles the scanning rate of the picture, resulting in a very stable, flicker-free image. Progressive scan video is available only from the component video output.
If you connect a TV that is not compatible with a progressive scan signal and switch the player to progressive, you will not be able to see any picture at all. In this case, switch everything off and reconnect using the supplied video cable (see Easy connections on page 14), then switch back to Interlace. Switch the player to standby then, using the front panel controls, press STANDBY/ON while pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Connect the psp side to the bottom right. Connect the tv side to the corresponding input colors. Your tv needs to have progressive scan and the right inputs.
Well, a progressive scan TV displays in the same resolution as a normal interlace TV. It's very hard to tell the difference in all respect.
Progressive rewrites every single line/pixel on the screen. Interlaced simply skips a line and rewrites half of the lines every frame. So, progressive can show higher quality, but interlaced was more predominant as it was easier to create for TV makers in the earlier days.
Most of today's better televisions are strictly progressive and you won't have any problems.
I'd try a different DVD player with the selected titles and see if the problem persists. It could be the TV or the or the player itself. If the titles work in another DVD player. Try a newer television and see if it works there.
hi. about that, 1 question, is your tv non hd? if not. you can do almost anything on psp to the tv wit that, but not games. to play games, you will need to use a hd tv and another type of cble named. psp component cable.
you need those to two to play psp to the tv. what a drag isnt it?..
Ok, I stopped short of going to Best Buy to get a new TV b/c my DAD suggested I pull the DVD player on another tv.
Dang it, he was right!. Same "audio no video" problem.
After playing with multiple buttons shooting blindly I found the [ I/P ] button restored the picture immediately!
This stands for Interaced or Progressive scanning:
from wikipedia
"Progressive or noninterlaced scanning is a method for displaying, storing or transmitting moving images in which all the lines of each frame are drawn in sequence. This is in contrast to the interlacing used in traditional television systems where only the odd lines, then the even lines of each frame (each image now called a field) are drawn alternatively."
So, my Dad says that "TV s are based on the interlacing" technology. I must have picked progressive scan while I was in the dark fast forwarding last week.
try to search on you tube - kr2008 for more details on how to play psp games on an interlace,non-progressive crt tv using composite or component av cable.this is now possible and thanks in no small measure to the plugin that was develped for this purpose.hope this helps.
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
I haven't got a tv which is good enough for the psp componets cable. But as sony psp manual says, http://manuals.playstation.net/document/en/psp/current/settings/index_videoout.html you probably need to setup your tv for the correct display type, not only on your psp, BUT ALSO YOUR TV SETUP!
Make sure the UMD is
properly inserted with the label facing the back of the PSP system.
Try removing the UMD and reinserting it.
Try playing the UMD on a different PSP system. If
the UMD plays, the original PSP system may be the problem. If the UMD
does not play, the problem may be isolated to the UMD itself.
Try playing
a different UMD on the PSP system. If another UMD plays, the original
UMD may be the problem. If none of the UMD's play, the problem may be
isolated to the PSP system.
Make sure the exposed UMD surface and plastic casing is not damaged[2]. Do not use if plastic casing is cracked, collapsed, or if foreign materials have entered inside the UMD enclosure.
