Question about Pioneer DV-363 DVD Player
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you help please?
  • Pioneer Master
  • 512 Answers
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Posted on Mar 05, 2011
  • Demonic-2011
    Demonic-2011 Mar 05, 2011
    Only download the document if you do not have the original owner's manual for this model DVD player.
  • Demonic-2011
    The back button is represented by 4 arrows (previous) on the main unit.
6ya staff
SOURCE:
My kid set it on progressive and now I don't know how to undo this. Please help
Unplug everything then reconnect. hold down the reverse button while pushing the stanby/power button. try once or twice until the progressive light goes out.
Jun 29, 2010 | Pioneer DV-363 DVD Player
How do I get the pioneer dv 363 out of progressive mode?
owners manual page 50-51!! Worked for me. It says unplug everything reconnect and hold down rewind button and push standby at the same time
Nov 27, 2009 | Pioneer DV-363 DVD Player
I put the player on progressive by mistake,how do i get the picture back,or can i reset it back to the factory settings?? thanks,rob
HI,
You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on.
Sep 24, 2009 | Pioneer DV-393-S
How to reset back to factory setting dv-310. Cant see pic after set to progressive scan
Power off DVD player, hold down Stop (square) button and power back on until display reads Clear. Viola!
Sep 19, 2009 | Pioneer DV-310 DVD Player
I accidentally pressed progressive scan on my DV 366 player and my TV screen went blank. I can listen to music now by there is no picture on the TV screen. How do I correct it?
You will have to press the progressive scan button again, but most of the time you will have to remove any discs that are in the unit first, before you press the buton again
Aug 30, 2009 | Pioneer DV-366K DVD Player
The video doesnt play in progressive
needs to go back to original video mode
Aug 15, 2009 | Pioneer DV-363 DVD Player
Progressive scan, no pictures on tv
Hold down stop button and turn on standby button this will reset to normal mode.
Mar 12, 2009 | Pioneer DV-270-S DVD Player
Reset to factory defau;ts
Small print in the manual says to hold down the 100/P.Scan button on the remote to toggle between progressive and interlaced. This was after I blindly tried to follow the setup screens in the manual and found that the manual doesn't match the exact screens (must be a firmware difference?) in the manual.
Also found that the factory default instructions in the manual do not include a yes/no confirmation screen.
May 26, 2008 | GoVideo DV2150 DVD VCR
Pioneer DV 266
You have two different formats that are incompatible with each other.
Apr 23, 2008 | Televison & Video
Progressive scan
lpug ur dvd. without turning the power on press and hold the stop button then press the power button
Sep 22, 2007 | Pioneer DV-373 DVD Player
Pioneer DV-363 DVD Player Logo
372 people viewed this question
Top Pioneer Televison & Video Experts
Marvin
Marvin
Ekse
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
