you must remove these transit bolts . after you do try it . of course the legs of the washer must be set to make the machine levl. and then make sure the lock nuts on each leg are tightened. with a level machine with the leg locknuts tight the machine should spin smoothly. if you fasled to remove the transit bolts first then you may have damaged the suspension. then you will have to call for professional service. good luck
Hiya .. the transit bolts are located under the lid at either side ..or at the rear... they are fairly long bolts which hold the drum and balance in place.. until installation. they will be sheathed in fairly hefty rubber grommets.
Screws for removal of lid located at the rear..2- or 4.. remove these slide lid front to back.. remove bolts if they are they are present... refit lid... note uneven siting of an appliance can cause excessive vibration as well!
