When i hit the vmail button it doesn't let me access my voicemail it only beeps and says incoming only
That button is not programmed for voicemail, sounds like someone was playing and gave you a Target Line...
Press FEATURE * 0...
then the button that is giving you issues...
If the button says ex: 145 Line 145 that is a target line...
If you see Feature 981 that means voicemail.
My guess is someone gave you a Direct Inward Dial [DID] (a direct number) to your set.
do you want info to take that DID target line off your set?
By the way, if you want the Voicemail button back on your set, find a blank button, or a button that you want to change,
-> Dial FEATURE * 3
-> Press the button you want to change
-> Dial FEATURE 9 8 1
Voila, you have now re-programmed a button for your voicemail.
