SOURCE: Message light won't turn off...Comdial 8212S
Try dialing (from that phone)
Intercom # 3 then that extension number(exp. 100)
SOURCE: Setting time/date on Comdial 7260-00
Go to this website and it will give you the instructions on how to change the date and time on your comdial 7260. http://www.vertical.com/media/pdf/comdial_SAB007_DX80.pdf
SOURCE: how do i record the main greeting on a comdial edge 120
I just went thru this.
Push the Voicemail button, hit # until it asks for mailbox #, then hit 70 for password. Wait for main menu, then hit 3 for options. Then hit 2 to record your greeting. Now the tricky part,,, I don't know if these are all programmed the same way, but it will ask for the number of the box you wish to change, ours is 800, then follow along.
good luck!
What I'm trying to find out is how you can import a prerecorded message (mp3) as your greeting.
SOURCE: comdial 7260-00 can't turn off dnd
It turns off the same way you set it :-)
Go to the idle phone and press #4. It's a toggle so if you do it again it will reset DND. There's also a FEATURE 4 command for one-time DND.
Here's a link to the DX-80 user's guide. http://public.carl.airpost.net/Phones/DX80-DETUG.pdf
Carl
First try adjusting the ringer volume up. Also, you need to be in the ring group to have your phone ring on an incoming call. If you are not in the ring group, you'lll need to contact your local tech service.
