20 Most Recent Avaya Corded Phone avaparp18d Questions & Answers
look online for auctions that sell in lots / bulk - ebay- propertyroom.com--etc3222
Avaya Corded... | Answered on Oct 14, 2016
Change your VMS Cover rings to a larger number.
Avaya Corded... | Answered on Aug 21, 2015
Your voice mail extensions are programmed incorrectly in the system. You need to enter the System Programming mode from Ext 10 or 11 and use #607 to set the correct voicemail extensions.
Avaya Corded... | Answered on Apr 12, 2015
The extra light means there is something programmed for that location. I would go into the extension programming and see what that button is set for. It could be an unused line or a feature not labeled.
Avaya Corded... | Answered on Nov 29, 2014
If this is happening on the entire system, then make sure you have the number of lines programmed correctly. If this is correct you may have a bad processor card. If this is a happening on an extension only, then the port/card may be damaged I would temporarily move the extension to another port on a different card and see if the trouble follows. If it does you have an issue with the phone not the port/card.
If you have a Backup & Restore card you can manually restore the system. If not you will have to restore everything by manually including voicemail greetings and automated attendants.
For a Partner 18D phone the process is a little different depending on the VM version you have. In general you press Intercom 777(gets you into voicemail) enter your password(default is 1234 or 123456). This is where the various system commands change. Listen for Mailbox Options or Greetings option. Press that button and you can setup, change or delete greetings.
From extension 10 or 11 you must log into System Programming. Press Feature 00 and then the Left Intercom button twice. Then press #103 and enter the time as a 24 hour clock or military time. For example 9am 0900 and 2pm 1400. Then press Feature 00 to exit and save.
Avaya Corded... | Answered on Sep 22, 2014
For most of the Avaya mail systems it is *3 after you have logged into your voicemail. If this is incorrect just listen to the prompts in your voicemail it will tell you.
Does this occur on all calls or just internal calls? Are you listening through the handset or speakerphone?
There is no AC fan unit in a Avaya 18D phone.
Is the Microphone on extension A working if you are using the speakerphone. If not try using the hand set with the intercom and see if that works. Can extension A call any other extension and be heard?
They are the 2 buttons side by side at the bottom of the 18 button field. Also above the volume and feature buttons.
Avaya Corded... | Answered on Sep 20, 2014
If you have a Backup/Restore Card. You can manually restore the system. If not, then you will have to reprogram everything.
Avaya Corded... | Answered on Sep 18, 2014
Avaya Corded Phone avaparp18d Logo
288 questions posted
Top Avaya Lands Phones Experts
martin hogg
Ekse
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Avaya Lands Phones
  • Avaya Lands Phones
Most Popular Question
assign new person extension
  • Lands Phones
