SOURCE: cannot send email from a Canon 3380i
Most likely you will have to log into the machines interface by putting the machines IP address in your web browser. Once there you will have to put the new email settings in the machine so it can email properly.
SOURCE: Canon imageRUNNER 5000 scanner
yes it can if you have the scanner driver borad loaded in the machine
Thank You,
Mikey
SOURCE: Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
SOURCE: Won't PDF to email
I had the same issue when migrating between exchange servers. basically the scanner settings were pointing to the old exchange servers IP. I set that to the new IP and it resolved the issue.
SOURCE: Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
