How do I change it
Maryfrancesh
Exerpt taken from Dell Laser 1100 User Manual (p30)
1 Open the front cover.
2 Pull the used toner cartridge out and lift it up and away from the printer.
3 Unpack a new toner cartridge. Hold the cartridge carefully and gently shake it from sideto-
side 5 or 6 times to distribute the toner.
4 Pull the tape to remove the protective paper.
5 Locate the cartridge slot inside the printer, one on each side.
6 Unfold the toner cartridge handle and grasp it. Insert the cartridge into the printer until
it snaps into place.
7 Close the front cover. Make sure that the cover is securely closed. If it is not firmly closed,
printing errors may occur.
PDF Manual can be found here -->
http://support.euro.dell.com/support/edocs/systems/1100/en/OM/OM_1100_en.pdf
The guide also contains pictures of what to do.
Andy
The owners manual,, which tells you how to change the ink cart. along with specs and other info , may be downloaded from dells web site at the address listed below. please rate this answer and good luck.
http://support.dell.com/support/edocs/systems/PRN1110/en/index.htm
The unit in question takes a Toner cartridge not ink as in an ink jet printer. Most replacement toner cartridges come with instructions for proper installation. Good luck and have a good day.
SOURCE: remove and replace ink cartrige
SOURCE: Low toner advise keeps on after changing toner and/or printing
Have you tried to unplug your printer and plug it back in, that will force the printer to re-check all its settings and it should notice that the toner is now full.
