Question about Dell AllinOne Multifunctional (v515w) InkJet Printer
Black Cartrige Missing
Printer was working fine today, then I ran out of ink. I replaced both black and colour cartriges with the new (correct) cartriges. Now I get a "Black Cartrige Missing" error message. Did all the obvious things (taking out and replacing the cartrige several times, turning the printer off, trying a different new cartrige, ensuring the metal prongs inside the carriage are not bent, etc). I don't get this error message with the old cartrige (except that I can't print anything because it's out of ink), but I get it with any new cartrige I stick in.
Michael Tarallo
    Sergeant:
  • 111 Answers
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
Posted on May 02, 2017
5 Related Answers
samkong
Samuel Konger
  • 106 Answers
SOURCE: Cartridge Problems.
Go to Printer & Faxes locate your printer> Right Click go to properties and maintenance you can reset the ink counter. hat should solve the problem.
Posted on Dec 05, 2007
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: printer says right cartrige is incorrect
remove the cartridges and reinstall them back, turn the printer off , if that does not work, did you use a new original cartridge or a recycled cartridge ?, either way will trick the printer into the new cartridges, i, hope this solves the problem good luck.
Posted on Jun 01, 2008
Anonymous
  • 564 Answers
SOURCE: remove and replace ink cartrige
  1. Write down the printer name and brand.
  2. Remove the empty cartridge and check the writing on it. If it has any bold and big numbers on it, write these down.
  3. Go to office supply store and give the clerk your notes.
  4. Make sure you get the right one and take it home.
  5. Check to be sure your printer is on.
  6. Open your printer's lid.
  7. Take out the old cartridge and put inside a small ziploc if you want to.
  8. Dispose of the old cartridge. Or if possible, have the cartridge recycled.
  9. Unpack new cartridge and place inside the printer.
  10. Print a test page.
  11. Reconfigure printer heads for best quality.
Posted on May 24, 2009
Anonymous
  • 33 Answers
SOURCE: Dell AIO 922 printer not seeing the color cardridge
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" Click here and slecet the operating system and download the drive
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Posted on Jun 17, 2009
KingDWS
Dave King
  • 1606 Answers
SOURCE: dell printer
Assuming you have used a Dell approved ink cartridge the problem is most likely just a dirty print head. If you haven't printed for a while (which can be only a week or so in hot places) you may have to run the cleaning process 5-10 times or more before you start to see marks on the paper. This is typical of all ink jets that are not used regularly. If you can not get it to print or it will not get good enough to print you can resort to manually cleaning the print head with a qtip dipped in viniger which disolves most inkjet inks. It won't take very much to clean and it will print like new.
Posted on Jul 09, 2009
How do i trick kodak esp office 2150 after refilling black ink
completely agree with you jeff! I think it just runs off of the date you put the last printer cartrige in or how many prints you have ran with it in. theres a little "microchip" thing on the front of the cartriges that if you switch that out with one off of a new cartrige, your old one will still work fine. but then you only have a certain amount of time/prints that will still come out of your new cartrige if you switch it back after the old cartrige is depleted. If you even deplete the whole old cartrige before the printer decided that the chip on that one is too old or printed too many pages...complete BS, I dont think I have ever been this mad at company before, and I will never ever buy another kodak product again!!!
Jan 08, 2013 | Kodak 2150 ESP Wireless All-in-One Printer
Colour Printing on a Samsung clp 500
Try unplugging printer from the power and connecting it back.
Try also extracting all toners and putting toners back.
Oct 30, 2008 | Samsung CLP-500 Laser Printer
My Lexmark printer 1270 only prints in black and white although the colour cartriges have good ink levals. This has just started happening, it was happily printing in colour not long ago. Many thanks.
Jast go to print option. Then Mantainance. Then try to print a nozzale. If all the colour comes out properly ( with out dot or misline), your cartrige head is goog for print. If not, your printer cartrige head is block. To reque from the problem follow the proces:
1. Unpluge colour cartrige.
2. Try to clean the cartrige head with soft cloth and amonia gentaly.
3. Try to out the ink through the head nozzale pore by using shaking or gentaly swape by soft tissue.
4. Now put the cratrige head upon a soft tissue. ( ink will comes out). If not, repit stage 1-4 until ink come out.
Thank you
Jun 07, 2011 | Lexmark X1270 All-In-One InkJet Printer
My Epson c88 was working fine. I changes ink cartridges and now the black will not print.
Your printer head may be closed.To remove the problem jast open ink cartrige from the cartrige chamber. set a seringe with full of black ink into the plustic pin which are tidely insert in the ink cartrige. After push 2/3 time your printer work fine again.
Thank You .
Shohagtush
Oct 20, 2010 | Epson Stylus C88 InkJet Photo Printer
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
Photosmart 3300 will not print black ink new cartrige. Self test failed,prints colours OK. page count 2698 Began problem perfect print top of page,fainter and blured as printed down page, replaced...
Take a dish- put damp tissue in it- if it can a one of the alchohol based cleaning tissue fine.
Stand the cart init for 10 minutes.
with a similar tissue give the contact sheet a wipe. and if it is flush to the bodty see if it has some give.
Reinstall and try
Jul 16, 2008 | HP Office Equipment & Supplies
Sharp AJ1800 printer - won't print colour
the color cartrige is defective. replace only with original cartriges
Mar 22, 2008 | Office Equipment & Supplies
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Not printing in black
Sounds like print head issue; have it serviced or u can try this :
How to Unclog Epson Print Heads
Oct 25, 2006 | Epson Stylus C60 InkJet Printer
Dell AllinOne Multifunctional (v515w) InkJet Printer Logo
49 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Richard C Cohen
Richard C Cohen
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
