Ricoh 4506 Copier Logo
Posted on Dec 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WASTE TONER IS FULL ERROR
ERROR MESSAGE THAT THE WASTE TONER IS FULL? THE PLASTIC CONTAINER ISNT FULL? NOT SURE HOW TO CLEAR THE ERROR. JUST CHANGED THE BLACK TONER CARTRIGE AND THE PRINTER SAYS ERROR: WASTE TONER FULL??
Chris Coughlin
Level 2:
  • Ricoh Expert 1,326 Answers
  • Posted on Dec 09, 2012
Chris Coughlin
Ricoh Expert
Level 2:
Answers
1326
Questions
Helped
441755
Points
872
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
5 Related Answers
James
  • 9 Answers
  • Posted on Apr 08, 2009
SOURCE: Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Anonymous
  • 58 Answers
  • Posted on Oct 29, 2008
SOURCE: ricoh aficio350e
You need to open an close the front cover a few times, this will turn the machine on and off and start the toner replenishment cycle. That should do it.
www.mfpsolutions.blogspot.com
Anonymous
  • 62 Answers
  • Posted on Oct 09, 2008
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Anonymous
  • 162 Answers
  • Posted on Sep 14, 2009
SOURCE: used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Anonymous
  • 263 Answers
  • Posted on Mar 10, 2011
SOURCE: I have a aficio mp
The wast toner is placed next (next) to the first tray.
To reach there open the front door and you will see a screw (placed on top toward the main swith).
After unscrew you will be able to open a small door that hides the waste toner bottle.
Be careful because it is a little messy.
Good luke. If you need extra help reply to me
Our kyocera printer says WASTE TONER BOX FULL. what does it mean?
there is a waste toner collector, it is a clear plastic container that collects any toner that is not transferred to the paper. after a certain amount of time it needs to be replaced (or taken out and dump the toner) depending on the copier it uses weight of the container or a sensor to block the light if full. if dumping into a plastic garbage bag make sure it is not dark so the sensor can reset, otherwise it thinks it's still full. You will have to Google where your waste toner box is.
My bizhub c25 waste toner was full so replaced and will not now reset.
The C25 stores toner in a waste toner container. On the front of that container there is rectangular clear window that fits into a sensor when installed into machine. The sensor passes a beam of light through that window. When the bottle is full there is toner inside that clear plastic window which stops the light from making it through the window and the machine will tell you the waste toner is full. Just dumping the container out will not clear that window and by putting it back in the machine you will get the same toner full message. If you are going to try to reuse that container you will have remove the black plastic cover that is glued to the container above the clear plastic. Then use something like a Qtip to clean all the toner off of that clear window(much easier and faster to just replace in with a new container). if you still get the waste toner full message after you install it then remove it and wipe off the sensor that the clear window sits in. This will clear the message and you can continue your copy job.
After cleaning waste toner container still showing waste toner full i cleaned the bottle and sensor path (transparent) error cleared and still showing wast toner box full
Did you clean the actually sensors in the copier it self???? Where the bottle goes in to place??? Try that and make sure the clear plastic is clean and turn the main power switch off then back on. Good Luck
6helpful
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Xerox 7120 waste toner error ...
The trick about cleaning out the waste toner container is you have to also swab out the clear plastic piece the optical sensor reads so the device knows the waste toner is full. Clean that out and you should be able to get more than a weeks usage out of the waste toner container.
Hope this helps.
2answers
Can't not print. Please tell me .....why? i'm printting is suddenly: E1 CHG. WST. T. CTN i don't understand
This error message usually means that your waste toner storage is full and it has to be changed. If this is not done you will have issues with printing. Check your user manual and see where the waste toner container is and it will also give you numbers for reordering new container from manufacturers site. Hope this helps.
14helpful
4answers
E000019-0000 in cannon 3300 xerox
E000019-0000 indicates that the Waste Toner container is full.
CANON CLC3220 COPIER ERROR CODE E0000001-0003
although the waste container is empty still it show 'THE WASTE TONER IS FULL' cleaned the bottle neck of waste container see to it that the 2transparent round hole area is not clouded by toner .this is the sensor path it should be cleaned(remove one screw to remove transparent cap)
1helpful
2answers
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
3helpful
4answers
"Waste toner tank full"message won't clear
I had the same problem with my printer. On the back of the waste toner cartridge is a tab that sticks out. A photoelectric shine thru this tab to let you know when the cartridge is full. My photoelectric had gone out and was giving the same error message. I took my printer apart and cut the wires loose on each side of the photoelectric and shorted them together to complete the circuit. The only problem in doing this is you have to occasionally check the waste toner cartridge yourself to make sure it does not overfill.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
