Canon LPB 2000 B
SOURCE: canon ir33ooi-toner
On a Canon iR3300 you do not remove the toner to refill. You have to get a new tube of toner. Open the front door. Release the developer with lever coloured. Slide out the developer unit till it stops. Insert the new tube on the developer and best way to do it is to follow the pictures instruction on the toner cartoon box. Also there the prccedure on the copier display how to do it.
SOURCE: canon x25 toner cartridge
Don't try and refill this on your own, you'll only have difficulty. Buy a reasonably priced compatible, that is "remanufactured" -not 'refilled'. It's not just toner that makes it work. The drum, cleaning blade, and doctor blade (at minimum) need to be replaced for proper operation, and there is also a toner waste hopper that needs emptying or it will overflow on second cycle.
Just my 2 cents.
SOURCE: what we use for refilling a laser toner. ink or
check here with no special tools
it is verey easy
SOURCE: just how to refill the
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
