Normal 0
Hi .
I have Kenmore refrigerators model 46-66812.
The problem with it that the water is leaking inside themain section of the refrigerator..
I defrost the refrigerator and opened the back panel of thefreezer (top part) and checked the drain. I was able to insert a wire onlyabout 10 cm. It felt like it is not just clogged with ice or something, butthat it is closed with something hard. Is it right? Should not it be open allthe way to the bottom? What could be the problem? What should I do?
I really appreciate you advice.
Ok sounds like a froze or blocked defrost drain.take a pice of weed eater line about 6 feet .tie a good knot at one end.then feed the unnotted end down the drain hole and pullout at other end.when you pull the nott witt clean drain.if it wont go thru it may be frozen.you can shut it down over night or use blow dryer.watch out for water and electricty
theres a j trap in that defrost line to keep air from comming in .a ridged wire wont work ive never seen any thing else in there.ive done thousands.i think once amana produced a model that the lite or somthing melted the defrost drain line .but that was isolated cases.if water is draining out of their pretty fast it may be fine and your chasing a goast
Normal
0
Thank you for your response.
I pored little bit of water in the drain in the freezer compartment
and it started coming out from under the back panel of the main compartment in
the place where middle rail for the shelves was mounted (there is small gap
there between the panel and the place for the screw), and from under the vent
hole on the top ( I removed the electrical assembly from the top of the main compartment).
Thanks
There is some ice on the freezer floor.
Normal
0
I tried to insert rigid wire into the drain from the top. It
goes inside only about 10cm and hit something hard, like plastic plug. Before I
did this I defrosted the refrigerator for 24 hours. It feels like the drain is
closed with something. And it is not ice. What could it be?
I also tried to insert the same rigid wire from the bottom and
it hit something hard half way to the top. Is the drain supposed to be open all
the time from the top to the bottom?
Thanks
where do you see the water. dry the water and trace where it begins ,is there ice on the frezer floor.
