Water is leaking on the floor. Inside fridge & freezer working properly. It's not the water filter; it was changed 2 months ago with no problem.
Check the external back of the for a pipe coming from the freezer that has a plastic u-bend in it or a rectangular block. This is the condensate drain from the freezer defrost system. Usually you get a dump of water in the middle of the night, so you come down in the morning to a puddle. Remove the part and soak in bleach and hot water. rinse, flush and shake the residue out. Sometimes but not often the drain under the freezer evaporator fins is blocked with ice. To fix that you have to remove the panel inside at the back of the freezer.
Or the drain inside the fridge side is blocked. Similar issue but not as severe.
Videos in the link that show the issue.
https://www.google.com/search?q=Kenmore+coldspot+model+106+53532300+leaking+on+the+floor
please double check that your freezer door is closing properly. You can also pull the fridge out and check whether the water is coming from the back of the of the fridge. If not, then that means there's a leak under the fridge and if that's the case you'll need to schedule a diagnostic on the fridge. You might reach out to Kenmore over the phone directly to ask them to send you a technician for this.
Thank you.
