I have a hp laptop compaq 6820s and i have a windows xp professional on it but when im on log on screen i click my account then types login in after 5 seconds types login out and im can t get into pc what im need to do
After reading your question carefully it is still unclear that you are able to login (for 5 seconds) or not. If you can login to your PC and logout automatically then I think someone (with Admin rights) has enabled automatic logout feature (depending upon the time). On the other hand, if you are not able to login with your user name and password then there may be some problem with your password (perhaps you have forgotten it). In this situation you can reset it by using password recovery software (click http://lmgtfy.com/?q=Windows+Password+Recovery+Stellar to get password recovery software list).
So it logs you in and then logs you back out immediately? If that's the case try booting in safemode by hitting f8 during boot.
SOURCE: HP Compaq nc6320 pc notebook issue
Paddy it seems windows login problem, may be you are not using correct user name or/and password or may be your password profile got currupted.
Anyway in your case as you have purchased it second hand, then you don't had have any specific program or file on the hard disk. So you can easily format your lap and installed new XP or Vista as per your requirement. It will solve your problem. But you should must have the device drivers to work and installed properly.
Yes if you will use new hard drive then you can install, but same things will be required as per above. So I will recommend you to install on same HDD don't buy new one.
If any problem, Just Ask me
Thanks
Iqbal
SOURCE: sound device problem
The problem is the software driver that will make your sound device is not installed.install the device driver.this wiil cure the problem.
SOURCE: HP --Bioscrypt Verisoft fingerprint reader -- Error
Oh your going to hate me but unfortunately under vista if your credential manager gets corrupted the only way around is a total reimage - back to when it came out of the box. To do a full reimage using your recovery partition on power up to HP post screen tap F11 until the recovery manager starts - select advanced tab - full system recovery no backup - full destructive - this time when you get to your client details for setup after the recovery process select your password with care and when the time comes for for the finger print reader enabling under the credential manager the finger to use is your right small finger = the little pinkie >> it gets less work and is less prone to possible damage - small irregulaties are enough to fail a reading.
So I hope this helps but unfortunately a full destructive recovery is required.
Glenn
rate me ok
SOURCE: replace worn touchpad buttons HP compaq 6820s
It's better and easier to just replace the whole touch pad assembly and top cover. It's all one piece...much easier and cost is the same.
This is the part number:
457616-001
Testimonial: "Thanks for quick response"
SOURCE: How do I adjust the screen brightness on a HP
Hi, Actually, the problem here is you don?t have any options in windows XP to increase the brightness without using keyboard. HP does not provide any utility with the OS as it is OEM. Try this · Click on start > Click on control panel..... · Click on power options.... · Click on " Change settings plan "..... · Adjust the brightness and save the plan..... And exit... that should work.... OR Replace the keyboard and get the all things working
