HP Compaq 6820s Business Notebook Logo
Anonymous Posted on Nov 23, 2009
Replace worn touchpad buttons HP compaq 6820s
How to replace worn touchpad buttons HP compaq 6820s laptop. The left button is so worn it's becoming very unresponsive.
What would be the Part number for replacement touchpad buttons?
  • Anonymous Mar 15, 2014
    drivers
Anonymous
Level 3:
President:
  • Master 2,653 Answers
  • Posted on Nov 23, 2009
Anonymous
Master
Level 3:
President:
Answers
2653
Questions
Helped
744858
Points
7663
It's better and easier to just replace the whole touch pad assembly and top cover. It's all one piece...much easier and cost is the same.
This is the part number:
457616-001
Testimonial: "Thanks for quick response"
Touchpad will not turn off
you may need to re-download the drivers from the hp compaq website, there are also other programs you can download that do the same thing as that button.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Hi. The colour on my HP/Compaq 6820s laptop is a bit dull in comparison to my second extended Samsung monitor. I want to adjust the colour settings on the laptop, but all I can find on the keyboard is...
If you right hand mouse click on your desktop picture, a menu will become available. Click on Screen resolution and then Advanced settings. There will be options inside that window to allow you adjustment of the display.
Hope that helps.
I need a left touchpad key. the plastic tab underneath is broken off. It is a hp dv5. can you help me?
Just try to fix the broken one their by any drop of solution or take your notebook to the hp service center wont cost you much..
Cost of a new touchpad?
It comes around 110 dollars or 5000 rupees. Its pretty expensive compared to other parts.
Sorry for your laptop. All the best.
1helpful
2answers
Can i get a new replacement touchpad for a compaq 615 VQ628EA?
Yes NO problems. You need to remove old one, and get the serial number of the unit, use that to get a new one. Also eBay and Craigslist, can have these too.
My Hp Compaq 6820s don't start when I press power button.
This simply means that the battery is dead. Pull the battery out and try to start it again (with the power adapter plugged in obviously). If it starts up, you need a new battery, if it does not start up you may have a bad power adapter or broken power jack.
1helpful
On a hp compaq 6710b where/ how do i switch wifi on?
The wireless button should be located on the top left part of your laptop. It will be the 3rd button from the left.
11bffdfe321d68aa11aa600332bfe03c.png e8721ff914fb66ee83d789398c8a2a31.png e8721ff914fb66ee83d789398c8a2a31.png d44fad740e4749adb4fe5f87725dd44f.png 1. Volume mute button with LED indicator
2. Volume scroll zone with up/down LED indicators
3. Integrated microphone 4. RJ-11/modem port
5. Optical drive 6. Media Card Reader 7. 2 USB 2.0 ports 8. HP Fingerprint Sensor 9. Integrated stereo speakers 10. Touchpad with scroll zone 11. Touchpad Buttons 12. Hard drive activity / HP 3D DriveGuard LED 13. Battery charging LED
14. Power/standby LED
15. Wireless on/off LED
16. Power button with LED
17. HP Info / HP QuickLook button with LED indicator
18. Wireless on/off button with LED indicator
19. HP Presentation button with LED indicator
20. WLAN antennas (with WLAN option)
21. WWAN antennas (with WWAN option
3helpful
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
