Read detailed article on how to reset password on Windows 7 laptop!
For HP Password Reset, you can use Windows Password Rescuer to help reset password easily. It can help reset Windows 8/7/Vista/XP/2008/2003/2000 administrator password on laptop or desktop quickly without logon.
You also can use Password Recovery Bundle 2012 to reset it.This Tool can recover password for Windows, Word, Excel, RAR etc.
Use a password reset disk To log on to the computer by using a password reset disk, follow these steps. If your computer is or was a member of a domain, go to the "Windows XP Professional " Windows XP Home Edition or Windows XP Professional Edition Restart the computer. In the Windows XP logon screen, click the user name that you want to use, and then press ENTER. Did you forget your password? You can click the "?" button to see your password hint. Or you can use your password reset disk. Please type your password again. Be sure to use the correct uppercase and lowercase letters. Click Use your password reset disk. The Password Reset Wizard starts. The Password Reset Wizard enables you to create a new password for your user account. In the Password Reset Wizard dialog box, click Next. Insert the password reset disc into the CD drive, and then click Next. Type a new password in the Type a new password box, and then type the password again in the Type the password again to confirm box. In the Type a new password hint box, type a hint for the password, and then clickNext. Click Finish, and then try to log on to Windows XP again
Note You receive the following error message:
Forgot Windows password and now you're just able to log in as guest? You can't remember the administrator password for your computer because you don't use it since a long time. How to recover or reset the password without reinstalling as you have important data on your hard drive or have spent long time to set up? In this tutorial we're going to demonstrate how to reset lost Windows password using some awesome tricks to help you log in again when you forgot Windows 7 password. Method 1: Reset Forgotten Windows Password with System Repair Disc. Method 2: Reset Forgotten Windows Password with Ophcrack. Method 3: Reset Forgotten Windows Password by Third-party Software, such like Windows Login Recovery.
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
You can find it out but you can't read it. If you forgot your windows password you can reset or remove it with window password reset tool. I recommend this site http://www.reset-windows-password.com/how-to-reset-windows-password.html
Do not worry when you forgot windows 7 admin passwords. I realize a quick method to recover windows login passwords, it need no computer skills and no reinstalling windows. A program called Windows Password Reset 9.0 can help you. Search Windows Password Reset 9.0 or open this site http://www.reset-windows-password.com/reset-windows-7-password.html Good luck!
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
For removing Windows OS Passwords in safety, I suggest program Windows Password Seeker. Not only work on XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to recover Windows Password. I burned it to a Usb stick. Booting up and clearing my password within just 4 minutes. You could Google Windows Password Seeker
Lost windows logon password isn't really a serious problem. I know an easy method to recover lost windows login passwords, only need to create a bootable CD/DVD or USB flash drive to recover forgotten windows password, I have made a bootable Disc with the program Windows Password Seeker and reset my administrator password successfully. You could Google windows password seeker
SMARTKEY Password Recovery Bundle is a must-have toolkit to recover/remove/reset passwords for Windows, Excel, Word, Access, PowerPoint, Outlook, Outlook Express, PDF, RAR/WinRAR, ZIP/WinZIP, MSN, AOL, Google Talk, Paltalk, Trillian, Miranda, Opera, Firefox and IE Browser, etc. Over 21 types of passwords can be Recovered instantly. Until now, these password recovery tools are the fastest on the market, the easiest to use and the least expensive..
SOURCE: HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
SOURCE: my HP Compaq 6720s DVD-rom won't read cd's or
HI
The issue could be with the corrupted driver files of the DVD drive. Also these kinds of issue might be caused due to iTunes.
However, run the following tool to find the issue and fix it. I hope this could help you. Let me know the status please.
Your CD or DVD drive can't read or write media
