I have a Toshiba 57HDX82 57 in. rear projection TV with HD.I have had it for about five years.
The problem I am having is , the whole set just blacks out , no picture, no sound.
And the power indicator on the front of the set blinks . After between ten minutes to half an hour I can switch it back on again and it may play for between a few minutes or several hours and blink its out again..
I have a 65 hdx 82 have the same problem it alredy cat fixed like 16 week ago still dose the same problem put now it realy black out put power red light is on need info I have a 65 hdx 82 have the same problem it alredy cat fixed like 16 week ago still dose the same problem put now it realy black out put power red light is on need info
AnonymousFeb 08, 2009
I just had the same problem. Does anyone know what is the fix?I just had the same problem. Does anyone know what is the fix?
You can't post conmments that contain an email address.
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Most of the time the Hyper Board failing is the cause of this problem. It will eventually get worse where it also affects the HD ins. Unfortunately the Hyper Boards are no longer available from Toshiba and have not been available for quite some time. My suggestion is to coast with it and replace the Set when the HD ins fail.
Sky Assoc
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Skyassoc
It sounds like you have the closed-captioning set to "text" mode. When set this way, if captioning is present the set clears the area where the text goes. You don't see the box on channels or programs where captioning isn't being used. On most TV remotes a single button controls captions, so it's easy to get into text mode without knowing it.
Check to see if the comp inputs have a red and black audio input. Those must be connected, second go inside the menu and make sure the inputs match..good luck..
Check the lamp to see if it popped. Try replacing it. Also check the web for class action law suit for these sets, Toshiba has an extended warranty for lamps for certain units.
take your set to a tech the tv system control circuit might have damage, that circuit controls OSD,channel memory. it is an ic that controls that circuit along with other components.good luck.
I have the same tv and had it fixed the problem is most likely the power supply a $50.00 part but I suggest you have a repairman do the fix. Total cost should be around $250.00 for labor and parts.Also unplug your tv for over 4 hours then plug it back in to see if it works they call this a hard reset.If this does not work after 4 hours try unplugging it overnight and then try it. That is what I did to use the tv until I got it fixed. The only thing it could be is the convergence circuitv if this is the case it should cost about $400.00
