Toshiba 46h84 with a great picture but no sound. It is not a problem with the audio set up of the...
(More)
Toshiba 46h84 with a great picture but no sound. It is not a problem with the audio set up of the tv. Any solutions?
My Toshiba 46H84 is not coming on the light blink red but nothing happens. If I unplug it. It kicks...
(More)
My Toshiba 46H84 is not coming on the light blink red but nothing happens. If I unplug it. It kicks on for 4 seconds, go green, shuts off. How can i fix it?
I have a 46" (model 46H84) with wavy vertical lines throughout the screen. How can i FIX this...
(More)
I have a 46" (model 46H84) with wavy vertical lines throughout the screen. How can i FIX this myself? Is it possible? I've pushed the touch focus button and nothing. There is a 'convergence' option in the picture menu, nothing happens when I try to select it.
I have a toshiba 46 projection model # 46h84, the picture is starting to get dark and had to bump up...
(More)
I have a toshiba 46 projection model # 46h84, the picture is starting to get dark and had to bump up the brightness so i can watch. does anyone no if it just needs the mirrors clean or is this a picture tube problem, i believe there is no bulb to change like most.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
