Back to:
Tags:
Motorola RAZR V3 Cellular Phone
White lines on razr screen! (by 3 users)
posted by mama92505 on Apr 18, 2007
I'm not exactly sure what happened to the phone, i have an 18-month-old daughter so there is no telling, but now the inside screen has a whole bunch of white lines going through it! the outside screen is fine. someone please help!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 21, 2008
I have the same problem with my Motorola Razor v3. It is only a few months old and was fine last night but this morning half my screen is white lines. I removed the battery for a couple of minutes but it didn't resolve the problem.
Comment by Guest, posted on Mar 27, 2008
yes the same thing seemd to happen to my sony ericsson w850..first it was lik a thin white line and then it began to spread...the phone is pretti new and i got it as a present and i would realli hate to have to replace it
Best Solution
posted on Sep 06, 2007
FixYa! (100)
MasterLe247
Rank:Master Master
Rating: 93%, 56 votes
you need to replace the flex cable. most likely it was damaged or what not. It proven, test and post replay
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on white lines on razr screen!:
I don't want to Accept this solution
Solution #2
posted on Apr 23, 2007
FixYa! (100)
RZRsucks
Rank:Wiz Wiz
Rating: 81%, 211 votes
Typically problems with your screen comes down to Battery problems. so try replacing that first. Remember with any new battery you need to let it fully charge and fully die twice before normal charging. If that doesn't fix the problem check the ribbons and the connections inside the phone. YOU MIGHT WANT A PROFESSIONAL TO DO THIS FOR YOU!!!! At this point if it still doesn't work start saving for a new phone cause your LCD is either blown or a major fix that will cost lots of money.
Thank You!
Solution #3
posted on Oct 07, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i'm having the same problem. i'm wondering if its because i left the phone open a few times too many.. there was one line on monday morning, now i have 2 lines.
Thank You!
Solution #4
posted on Oct 18, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Buy nokia phone :D
Thank You!
Solution #5
posted on Jul 27, 2007
Not Rated (0)
Freddy009
Rank:Master Master
Rating: 86%, 56 votes
Try removing the battery and reinserting it, that would remove those lines which were also caused by my 2-year old. I had no idea how he did it. When i remove the battery it fixes for a long time.
Thank You!
Can you Help with these Cellular Phones problems?
the top of my phone broke off, everything else works, if i...
display and keypad shuts off and will not come back on...
utilice los trucos para ampliar memoria del v3 y ahora no...
hy could someone help me please. i have a motrolla v3...
I purchased a Motorola V3 RAZR cellular phone, but I...
Loading problems.
Repair Service
Find Cellular Phone Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
