Question about Motorola Mobility RAZR V3i Cellular Phone
Replacing cracked outter screen on my Razr V3i
Is there a manual on how to replace my outer screen on my phone? Do I need special tools?
Posted by msmustang on
  • lildrummaboy Dec 04, 2007
    after takeing out the screws what do i do next cuz the outer shell and inner shell will not seporate i am going crazy and dont want to hurt my phone
  • Anonymous Jan 09, 2008
    My outer screen cracked within 2 weeks of receiving phone.
    I've managed to obtain a replacement screen but it has no instructions with it. I dont want to force phone appart so would be grateful if someone could give me step by step instructions..
    Many thanks
Anonymous
Http://www.ryanbibbey.com/2006/10/27/how-to-replace-your-motorola-razr-lcd-screen/
Step by Step instructions with pictures. You cant go wrong with this guide!
Posted on May 23, 2009
waikikibunny
    Problem Solver:
  • 5 Answers
The exact directions can be found on youtube. my 10 year old daughter replaced her own after I purchased the screen
Posted on Jan 10, 2008
  • waikikibunny Jan 10, 2008
    Here is the link
    youtube.com/watch?v=EHkTatI-_s4
    Where did you get the replacement screen?
Anonymous
    Problem Solver:
  • 7 Answers
A torx 5 screwdriver should do the trick as for the replacement try here: http://www.formymobile.co.uk/proddetail.php?prod=v3ilcd
Posted on Nov 24, 2007
What are common faults of Motorola RAZR V3i Cellular Phone?
This is a very good cell phone, however the common fault is the screen lens is easily cracked and the printed circuit ribbon from the phones main board to the flip up screen breaks and you can't see the screen, and that is about it.
2answers
My phone says contact your server
most probably your phone has a software problem and need to be reformat.
there is no available manual format for razr v3i so we need a special gadget to reformat it.
the cheapest way to fix your phone is to have it reformat at your nearest service center or repair shop instead of buying those expensive gadget for this problem.
HAPPY NEW YEAR!!!
Where do I buy the outer replacement screen for my Razr's cracked one?
The original screen will cost you around 1500 to 2000INR. You can get that in authorised motorola service center located in the city. You didnt mention your area and location. So we cant able to help you out in finding the nearest service center buddy!! Am really sorry abt that!!
Repair front screen on razr v3i
It would be best to take the phone and hve the lcd replaced by a professional tech to save any damage that you may cause on the phone.
1helpful
3answers
CAN'T HEAR RING TONES ON MY RAZR V3I CELL PHONE
Your outter speaker is damaged - you got to love ebay!
Contact your seller and request a replacement or refund because it will cost you upto $50 to fix it
Outer display is not workin v3i phone
chang the display or chang the steap,and more important faltfinding
Outer display is not showing any think
check the display settings in ur mobile . there  is option of 'ON/OFF ' of outer screen  in ur h.set
Broken outside screen on razr V3i
hi guide to place front broken glass v3i open phone at the top you will 2 rubber covers remove them with a pin (pick them out) then at the bottom it will be the same but these are little round rubbers also pick the out now you should have 4 screws visible use the screw driver to remove them then once removed use the prize tool and insert it in the bottom of the v3 twist it and it should unclip remove outer panel remove glass its stuck on there very tightly but asgain prize it off then put the phone back together but dont put your glass in yet wait till its back together then remove backing tape from new glass and push it in place once your phones back together but dont push to hard lol or you will need another glass hope this helps mrjazon
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Relax
Relax
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
